Question about Konica Office Equipment & Supplies
We need to change the transfer unit on a bizhuc C250. I know I have to remove 2 screws but I am not sure where they are.
I found out we had a plan with Konica Minolta for tech assistance so we just ended up calling them. The guy removed the 2 big screws holding the metal brackets in line with and on either sides of the transfer unit and it slid right out.
Posted on Nov 05, 2008
Transfer unit c352 change
open right side remove two screws which release locks one to the rear on to the front, pull belt assy out, install new one reinstall locks
Jan 27, 2014 | Konica Minolta bizhub C250 All-In-One...
My Minolta Bizhub c250 has lines of blue and red going though the images. It also seems to be printing Dark. Is this likely a drum issue or something to do with the fuser or transfer belt?
Open the front cover pull out the Cyan,Magenta,Yellow,Black image unit,clea used a vacum cleaner the copier inside.Open the right cover and remove 2 srews,remove the transfer belt unit and clean the transfer belt cleaning blade and the transfer roller unit located on the right cover.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
P-21 error of c250
4 Change PRCB.
I have a konica Minolta bizhub C250 and the screen is reading "replace transfer unit" and "replace fusing unit". I contacted a local repair guy that said he might be able to reset the counters and the...
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
Oct 08, 2010 | Konica Minolta bizhub C250 All-In-One...
How to reset the transfer unit (fuse?), do you
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
May 15, 2010 | Konica Minolta bizhub C250 All-In-One...
WHERE IS THE TRANSFER UNIT LOCATED ON KONICA
Unit is in the right side cover. New one should have instructions with it, but I think you unlock a handle and swap, then lock handle again.
Apr 06, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Change the transfer unit on a konica Minolta bizhub c252
open right door, remove 2 lock screws and pull out the tbu
Dec 09, 2009 | Konica Minolta bizhub C250 All-In-One...
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Transfer unit on bizhub C250
its not so hard, open side door, remove 2 screws, and pull out the transfer unit gently. and reinstall new TBU. BE VERY CAREFUL WITH NEW UNIT, DO NOT DAMAGE IT.
Jun 19, 2008 | Konica Minolta bizhub C250 All-In-One...
32 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
