Question about Audiovox SIRPNP2 SIRIUS Radio Receiver
Sirpnp2 reciever gets hot and loses signal.
The Audiovox sirpnp2 gets hot after a while, very hot. It loses signal and I have to allow it to cool down then it works fine.
  • Chris Goran May 20, 2009
    Same problem, the receiver play sfor a few hours, but then it gets very hot and loses the signal...
    Audiovox SIRPNP2
I had the exact same problem with Sirius radios. I bought two Kenwood DTS-7000S receivers and both were sent back for warranty. Of the two, they only fixed one but by the time I figured out the other was bad, it was out of warranty. Kenwood, along with the repair community state they do fix such units, they toss them out. The thing that gets hot hot hot is the part that receives the Sirius antenna inside your unit. If you're like me and have nothing to lose then I recommend doing some cutting with a dremel and adding a small computer fan. It just takes a light breeze to keep that part cool enough (but it does take some sort of breeze, convection is out). For a home unit, find an old A/C power supply and match it to an old computer fan of equal or less voltage. For car, find a fan that uses 12 volts or less. It's an easy fix, really!
Posted on Dec 20, 2008
Poor Heating in 2000 Ford Taurus, Recieving cool Air through Blower
First place to check is the thermostat. It's like a float that allows coolant to pass from the hoses through the block. If it gets stuck, you'll lose heat. Easy to replace, and inexpensive.
Oct 08, 2013 | 2000 Ford Taurus
Unit shows 3 bars for signal strength yet the
This is a very old radio, and your antenna could be shot too. Try another antenna first.
Mar 01, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
The audio cuts in and out intermittently
IT COULD BE ONE OF UR SPEAKER WIRE A TOUCHING AND GROUNDING OUT LOOK AT UR SPEAKER. AND IT COULD BE ONE OF UR SPEAKERS IS CONNECTED WRONG WITH THE POSITIVE ON THE NEGATIVE CHECK THAT OUT TOO ALL SPEAKERS NEED TO BE POITIVE WITH POSITIVE AND NEGATIVE WITH NEGATIVE
Jul 04, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
How do i unlock or modify audiovox sirpnp2
call up Sirius and see if they have any manuals for that model to see if they can unlock it for ya or just have Sirius erase the reciever and start fresh by them reseting Hope this helps
Cheers
Johnthetr870
May 15, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
I inherited a disfunctional SIRPNP2. The signal strength meter in the lower left corner always displays an "x". Anyone have an idea? Thanks
A couple of things to try. First, try pulling out the anntenna from the back just slightly. My SIRPNP2 gets a better connection that way. Also, check to make sure that your annenna isn't bad. If you have a friend that has Sirius, connect their anntenna to your unit. If it works, replace your anntenna.
Apr 24, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Check your copper pin cylinder on the back of the receiver that goes into the cradle. The metal cylinder surrounding the copper pin can shave off or crack, causing these problems. If you can put your hands on another unit, you can replace this area with the parts unit. Unscrew the two screws holding the unit together and then slowly pry the unit apart, inserting a very thin blade and moving it slowly around the frame. Once inside, you will see screws holding down the area with the copper pins. You can remove this and put it in your receiver.
Aug 15, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Pin in back of receiver broke off
If you can put your hands on another unit for parts, you can open it and replace your damaged pin with one from the unit for parts. It takes a little time and care but you can do it.
Mar 17, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Bad sound
Being as the set is hooked to a satalight and simply playing what the signal is the problem has to be with the satalight reciever
Feb 07, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
X act sirius streamjockey
any trees or build in the way no signal
Dec 16, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Antenna not detected
Call Audiovox support. After waiting an hour I was told the unit (pnp2) was faulty and I was to call customer service to arrange a replacement. Mine is on the way to NY.
Jan 15, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Audiovox SIRPNP2 SIRIUS Radio Receiver Logo
259 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
