Question about Mitsubishi VS-55601 55" Rear Projection Television
Green Wavy Lines, and lower Convergence Issue
I am having an issue with my Mit VS-55601. It shows green "wavy" lines at the top of the screen, and then the green convergence is bad on the bottom 1/3 of the screen with the worst at the bottom (makes an upward arc like the St. Louis Arch with the middle being almost converged). So it appears it's only the Green, and only verticla (Red/Blue and all horizontal convergence seems fine, and I can adjust the Red/Blue in the adjustments). This did this really bad for 20 minutes one day. I turned it off for 20 minutes, turned back on and everything was fine for the rest of that day. Now for 3 days in a row it's had the problem return. I have tapped and reseat all the internal boards, and noticed no changes. I read a bunch of the posts, and most seem to suggest the convergence chips. My questions are: 1. Would the fact it broke, then worked, then broke again and that it is only the green gun, and only in the vertical direction, be consistant with the convergence chips goign bad? 2. Would removing the convergence board (any ID info would be great) and checking resistors feeding the chips and all solder joints help (or a waste of time)? 3. Say I replace the chips, would I need to do convergence adjustments after and if so how hard would that be? (if I have to start moving the yokes etc or sliding the magnets.. I'll call someone... :) ). 4. How much should this run for an at home repair? I can't get anyone to give me an estimate as they say it could be so many things, but not even ballpark on just the chips (which worries me). 5. Any other suggestions on what to check, where to buy a manual of schematics (readable and preferably original, vs downloaded). I saw several parts links to buy the chips in other posts. :) OH, and any suggestions for how to discharge the anode's on these tubes? I usually do the screwdriver under the suction cup method, but can't see where the leads enter the tube. Does the front just pop off to allow better access? Any help would be greatly appreciated. Thanks, Buzz
  • Jay Gallagher Oct 04, 2006
    Thanks jomaru! :) I will give it a try. To clarify, this does fit a convergence issue problem.(?) And also, the board I need to resolder is the big one on the right with the RF shielding over most of it and the large heat sink off the top, correct? :D
    I just didn't want to start diving into resoldering if this was a non-convergence related issue.
    Thanks again! I'll let you know how it goes.
    Buzz :)
  • Jay Gallagher Oct 05, 2006
    Update:
    I removed the convergence board (disconnecting all connections) and found the following:
    1. No resistors were burned, no overheat marks, and all the pins on the SK convergence chips looked ok.
    2. I saw that one resistor and 2 pins on the VGR connector had flux near them (assuming this means someone had replaced these in the past). By tracing the solder traces these seem to be related to the center convergence chip and trace to the VGR connetor (assuming this is for the green convergence).
    3. I removed (solder) and resoldered all the main resistors and flowed clean solder on them. I also reflowed the solder to all pins on the center convergence chip.
    4. On powerup, I jiggled all connectors to the convergence card and the corresponding connectors on the yoke of the green tube (carefully!). I also adjusted the screen and focus for the green tube (worked fine).
    None of the above changed the result. I still have convergence issues with the green tube and *only* in the vertical direction.
    I spoke with a local tech friend who said something about each chip has vertical and horizontal convergence sections and there are separate sections per color (he said 2 chips: 1 vert 1 horizontal, then 3 colors per chip, but doesn't work on Mitsubishi's). From what I can tell this is 3 chips (1 per color) and guessing each chip has vert and horizontal sections.
    Is the above correct? If so it would seem the chip could be bad for the vertical section.
    The big question I have is this: If the chip went bad, why would the TV exhibit the problem, then have it go away for a day, then come back again? I would think once it goes bad it would stay bad?
    I may order the chip and just replace it and see if anything changes, given I am dreading any manual convergence after replacement.
    Is there a good source for these chips? Also, anyone know the SK number off hand? I will dissassemble tomorrow, but would like to order it tonight if anyone knows the number (I'll research the posts just in case).
    Thanks for all the help! :)
    Buzz
The old convergance on older sets worked basically of capasitance,thru resistors,diodes and caps.on these stk chips they have circutry also of these componets.sometimes you have to buy one or two of them to correct your problem.shelf life has something to with electronics also.part tolerance plays a part.these stk circuitry connect to each other on the convergence board by design.if you have one dominate color issue it is possible that maybe that color tube needs to be checked.retrace issues maybe what you have.or on your picture tube board circuit.
Posted on Oct 07, 2006
    Sergeant:
  • 337 Answers
Before you call for help is a good idea if you check the solder conections to the convergence Ic's and resoldered them and while you are there check and resoldered any overheated areas.If the soldereing corrects the problem you will not have to worry about convergence adjustments,as long as the set is unplug you can carefully work in the chassis without having to touch the anodes of the picture tubes,stay away from them.Lets us know how it goes.
Posted on Oct 04, 2006
  • Omar Urrutia
    Omar Urrutia Oct 05, 2006
    This is a convergence related issue, the converge Ic's should be mounted on a heat sink and they are marked STK.... on its face,Be careful when fliping the right board to look, while you do it some conectors might get disconected ,most of the wires are long so you can pull the chassis but others might have to be disconected and the reconected when done.
Wavy lines on Mitsubishi ws-a55
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Mitsubishi VS-55601 55" Rear Projection...
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Red, Green convergence lines are wavy
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Wavy Red lines
hi there,
if you are familiar with electronics you can do this :adjust voltage at hight voltage block it has screen and focus written on it and comes from flyback transformer,but be careful cause it can be to dangerous if you touch something else,ah,ah adjust only the one that says screen and has a R on top,that means red,ok,thanks.
Jun 19, 2008 | JVC AV-48WP30 48" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Televison & Video Logo
343 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
