Question about Kenmore Elite 45986 Front Load Washer
F 29 24 hour old unit. Displays F 29 and door will not unlock. Have tried calling Sears for technical help. Walked throught the troublshooting. No help. Can occasionally get door to open and code to clear by randomly pressing buttons. F 29 will return after cycle has completed.
    Sergeant:
    Champion:
  • 324 Answers
Bring it back they have a return guarantee.
Posted on Nov 07, 2008
My chamberlain wisper drive plus does not hold memory
call chamberlain on there 800 number a tec will discuss the problem with you.
You can reach our friendly and knowledgeable technical support staff by calling1-800-528-5880
May 09, 2014 | Sears Craftsman LiftMaster Chamberlain...
Is there a number i can call to get tech support on the chamberlain motion detector system?
You can e-mail Chamberlain at technical.support@Chamberlain.com or you can call their Technical support hotline at 800-528-5880.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Kenmore 12,000 BTU unit 60days old compressor dead
  1. Sears or any firm that sells a Unit has to have a chance to look at the problem and repiar it, if you installed it WRONG that is Bad ! Sears will not be responsible for damge to the Unit, bring it to them, you might have to leave it for days - better to have a serviceman come to the home - Units are covered for 90 days all but Electrical ( ???) You better have the bill of sale ( date purchased ( not installed !! )
Jul 17, 2009 | Kenmore Heating & Cooling
Brand NEW Whirlpool Duet Sport
After six failed attempts by your machine to lock the door F22 flashes.
Causes & Procedure:
Door lock mechanism is broken or removed from door.
Door switch or door unit failure.
1 Unplug / disconnect washer.
2 Check door switch lock unit.
3 Check wire harness connections to door switch/lock unit & the
Central Control Unit (CCU)
Fault 22
Push the door to make sure it is locked firmly (try some WD40 on the door mechanism on machine, not on door, to ease out any lock jam & try the door open/close with the power off the wall) I'm giving you tips to avoid the so-called techs zooming for your wallet.
Fault 28
The communication between the CCU & the MCU (motor control
unit cannot be sent correctly.
1 Unplug washer / Disconnect power
2 Check wire harness connection to the MCU, the motor & CCU
Check communication of the CCU board within the housing.
Make sure all grounding switches are engaged.
3 Check the drive system for any worn or failed components
4 Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
5 Verify CCU operation by running the Diagnostic Test or any
cycle after plugging in.
Will try getting back re the door lock. Desperate i know, so am i.
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE5t Washer Door is locked, Cycle didn't run, Won't power down
Click on the following link for advice on how to unlock the washer door by using the manual release.
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Even though your washer probably isn't diaplaying any error codes (according to the symptoms you've provided), the condition still exists where you have a door lock issue. You can try unplugging the washer for about 30 minutes to see if the computer will reset. Sometimes the door lock jams for whatever reason and a manual release and/or power cut off will clear it. If for some reason, the washer still exhibits the same problem after following the advice in the link, any further repairs would be covered depending on the PURCHASE date of your washer. If you do not have a receipt, Sears will determine the date based upon the washer serial number. The serial number indicates the month and year the washer was manufactured. If you provide me with your COMPLETE model number, I can tell you if your washer would still be covered under the manufacturers warranty. I hope you find this information helpful.
Jun 16, 2008 | Washing Machines
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
Kenmore Elite 45986 Front Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Robert Rankin
