Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Flashing Green Light TV will not turn on
The green light just flashes constantly TV will not turn on. I know it has to do with the DM board but could not remove it from the TV is there illustrations out there that will assist me?
  • 9 more comments
  • ardnas1886 Nov 04, 2008
    my mitsubishi ws-65613 cant start on and the the green light keeps flashing
  • niesty Nov 04, 2008
    Wow I have the same green blinking light problem on my Mitsu WS-65513.
    niesty2@yahoo.com
  • Pistol23 Nov 05, 2008
    Please send them to pc_eclipse@yahoo.com. I have seen instructions for a 55 inch Mitsubishi and after looking at my 65 inch DM unit it is a little different. Thank you so much!!!
  • tormented77 Nov 08, 2008
    GREEN LIGHT KEEPS FLASHING CAN'T TURN ON
  • Pistol23 Nov 08, 2008
    ardnas1886, can get the capacitors from Radio shack part number 272-1032 call before you go make sure that one has them
    Hey Jaime,
    replaced capacitors and the green light turned off and then tv turned on but now I have no picture, I have sound but no picture. Might you have an what happened??
    Thanks,
    Pete
    Jaime867,
    Please ignore my further inquiry, I neglected to plug in a wire I had disconnected. My TV is now up and running it just took around 40 dollars at Radio Shack and some time. Thank you so much for the instructions I would not have been able to do this without your help. THANKS!!!!!!!!
  • Malcolm Bacon Nov 10, 2008
    Please, please, Help someone. I love my WS-65 and don't want to replace it right now.
    If anyone has detailed repair procedures for the blinking green light problem, would u be so kind to send to me.
    my email address is: savvyvett@sbcglobal.net
    thanks in advance!
  • ldp1959 Nov 22, 2008
    I have removed the board and replaced the capacitors, still the blinking green light. Are there any other fixes I can try. The capacitors I took out looked fine.
    Thanks
  • chaly63 Dec 28, 2008
    I have the same problem can't turn on my TV it keeps flashing the green light, any one can help me?
  • ardnas1886 May 11, 2010
    where can i buy the capacitators???? in which store??/ or do i have to ordered them
  • 2,326 Answers
Where do I send you the info with illustrations?
Posted on Nov 04, 2008
  • Jaime Hernandez Nov 04, 2008
    You will also find some info by clicking here.
  • Jaime Hernandez Nov 05, 2008
    @ Pistol23,
    The instructions I've emailed you are very similar to the DM board in your TV. The capacitors should be easy to spot once you remove the DM board from the TV and the metal shield from it.
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I turned on the TV but just got a black screen but could hear audio just fine. Turned the set off and unplugged it. When I plugged it back in the green timer light started flashing and would not stop...
Nonstop blinking is likely a DM or format board - format board most likely. I have rebuilt several of these by simply replacing all the caps, about 70 of them, and takes about two hours start to finish... But this set does need to boot. It takes about 70 seconds of flashing green light before you're able to press the power button - even when everthing is working as it should..
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green light flashing
this means the DM board is not booting up. You will typically need 4-8 capacitors to fix this issue. you have to pull out the board and solder in new parts. let me know if you feel skilled enough to do this and I can give directions. The caps will usually bulge at the tops and are 1000uf .. mitsubishi recommends replacing with 680uf 16v caps..
Jan 02, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Timer light flashing
The capacitors wont always show any outward signs of being bad. But it the LED blinks constantly without stopping thats telling you the DM isnt completeing the boot sequence. So most likely the capacitors are bad. But dont put the same ratings back. go with 1000ufs @25V but make certain they are the 105 degree celcius capacitors. If you need further assistance let me know
Jun 17, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
