Question about Microwave Ovens
Replace OTR Microwave
I need to replace an Ewave OTR microwave I bought at Home Depot. What brands have compatible mounting brackets? Do all brands use the same mounting bracket, or are they all different?
  • Anonymous Nov 09, 2008
    Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
  • William Miller
    William Miller May 11, 2010
    Brands don't usually swap, but models of the same brand often do.
    What model number do you have?
    What problem are you having? It may be an easy fix...
Posted on Nov 09, 2008
Anyone know how to secure a GE profile JVM1190WY004 over range microwave with no mounting plate?
The ge mounting brackets are pretty universal between all the ge OTR microwaves over many years.
Nov 15, 2016 | GE Microwave Ovens
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
Just bought new Samsung SMH9151 OTR Microwave. Installed it and it turns on for 3 seconds and turns off. I took it back down and just plugged it in the wall plug (while sitting on the counter) and same...
I don't mean to be coy, but if you bought it from a local company (Best Buy, Lowes, Home Depot), take it back (within the 30 day window) for a refund. I bought three microwaves (all poor quality) and returned them all!
I may be returning this Samsung if your review turns out to be true for my microwave.
Jun 03, 2010 | Samsung SMH9151 Microwave Oven
Can I replace a 1.3 cu ft otr microwave with a 1.5
Brackets can remain the same throughout a particular brand for several years but will also change every year at times. Same year and same brand, I would say yes. Different year of manufacture or different brand name I would say, no it will not fit the existing brackets. If you have a particular brand in mind and have the model number of the existing OTR, it is usually possible to search out installation instructions for both at the manufacturer's website. You could then compare to see if they will match up. The two screws through the upper cabinet floor into thr top of the OTR can vary, within a particular brand even in the same year of manufacturer.
Mar 14, 2010 | Microwave Ovens
I currently have a non-working over the range microwave, I have bought a replacement. How to I take one down and replace it with the new one?Are the brackets interchangeable?
What brand Microwave are you removing and what brand are you installing? If the are not the same brand they will mount differently. On an older GE you remove the two screws holding the unit in place. They are located on top of the unit on the front. Look in the cabinet above the microwave. After you disconnect the vent pipe the unit slides forward and out. On some other brands the unit will pivot down and then you lift it off a mounting bracket. To make the job as easy as possible and to make sure the vent pipe does not have to be moved, remove the old unit before buying a replacement. Look at how it mounts. Then buy the same brand and it should mount the exact same way, so you could use the old mount. But even then the manufacture may have changed the way it is mounted. I just replaced a GE with a Whirlpool and they mount completely differently. I even had to move the vent pipe 2" to the right. So stick with the same brand and hope they have not change the mount.
Dec 15, 2009 | Microwave Ovens
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Installation of undercabinet microwave
If the OTR is the same model, the mounts should be the same. As long as you use the same bolts/screws from the old one, or the same length new bolts/screws, it should be a fairly simple exchange.
Mar 24, 2017 | GE JVM1440 Microwave Oven
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Removing a Sharp Carosel R 1440 over the stove microwave
you should be able to do this yourself. Do you have an outlet to plug this into, or will you need to hard wire it into your apartment/house wiring/. If the former, then you should be okay. You will need a bracket/plate to mount the microwave to.
May 26, 2008 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
1,197 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
