Question about Lands Phones
I HAVE CORDLESS PHONES THREE WITH A BASE STATION .. RECENTLY ONE OF THE PHONES ONLY SHOWS NOT REGISTERED MDL DECT 160 AND 180IT DOES NOT WORK AS FAR AS USE IS CONCERNED BUT LIGHTS UP WHEN LIFTED OFF THE BASE.THE BATTERY SHOWS FULL. WHAT CAN I DO ?
The phones are in the garbage-replaced purchased from another company
Posted on Nov 05, 2008
PROBLEM WITH THE BASE GIGASET A120
Thank you for these instructions. I have Siemens geigaset A120 with three handsets and one of the handsets stopped working about a year ago and my previous tries att registering it at the base station had failed and I was about to give up and buy a new set for 80 Euro, but I decided to give i one more try at registering and it worked the third time around. So do not give up. When one your hand sets stops working (no dial tone and can not call from it) try re registering as described above.
Nov 23, 2012 | Siemens Gigaset A120 Single Dect Cordless...
My cordless home phone showing REGISTER! on its screen and i am unable to make and receive a call.
The handset needs to be registered to work with the base. Since you didn't specify the model of your phone, I can't give you specific instructions for this. Select the model of your phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl
to get the manual.
Jul 19, 2011 | Uniden DECT 6.0 Cordless Phone ID
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Please register on the screen
When you see this 'register' message, it means that that particular DECT handset must be registred to the selected 'Base' station: please consult your User manual/guide for the steps by steps instruction on how to register a new handset to your base station for the specific compatible model(s).
Hope it helps.
Jan 27, 2010 | GE 25931 Trio Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Dec 22, 2008 | Philips DECT 2252S Cordless Phone
Phone registeration
i have sort of same problem! I recently bought Panasonic KXTG7223E TRIPLE TAM DECT Cordless Phone.
I have tried to register one of the hand set to the base unit but funny enough it has been regitered to my neibour's phone! I have tried to deregister it but does not let me! can any body help please?
May 29, 2008 | Panasonic KX-TG1033S Cordless Phone
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Mar 29, 2008 | Philips DECT 2151 Cordless Phone
Ge cordless phone station 2 shows unavailable
You have to register the hand set in the main base. Place each handset in the base for 15 seconds minimum. It will change form unavailable to Ready when it grabs the signal from the base. If the power goes out, you will have to re-register each hand set in the base before you use them again.
Jan 14, 2008 | GE 25932 Twin Cordless Phone
Lands Phones Logo
81 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
