Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer model 556
Powers up and carousel turns to proper location, but will not proceed past that point. Record pick arm does not move to grab record.
  • 1 more comment
  • crossbow196 Nov 10, 2008
    Yes, that's what the serial plate says. Built in the mid- or late-60s, apparently. It's all-transistor; no tubes. Thanks for the lead to victoryglass.com. I'll check 'em out. Thanks!
  • crossbow196 May 11, 2010
    I don't need a plan. I need a service manual. Who has one they'd like to part with? Or a copy?
    Wurlitzer model 556 jukebox
  • Anonymous Mar 27, 2014
    a friend had played a record and when the grab bar went to pull it out the record got stuck as it was being put away, I pulled back on the grab bar to free up the record wheel and something broke? now nothing happens when records are selected
556 would be the model of the amplifier. If you don't have easy access to the back of the jukebox to look at the ID plate, if you look to the right of the amp, that other chassis is the 'control box'. The control box will be marked for example 'Model 3800 BO/AC'. The four digit number is the model of the jukebox itself.
From the symptoms you describe, it sounds like the machine may have faulty 'readout switches'. This is a bit of an unfortunate situation in that new replacements are not being produced. In this situation, I would check with John Durfee (www.jukeboxparts.com), as he will have the swtiches, but the operating condition of said switches is strictly 'as is', seeing as they would be taken from a salvaged Wurlitzer.
Posted on Dec 27, 2008
    Champion:
  • Wurlitzer Expert
  • 211 Answers
Are you sure you mean 556? Sounds an odd model to me. The model number is on a black metal plate the size of a credit card on the back of the jukebox (usually).
Manuals can be found at www.victoryglass.com (USA) and The Jukebox Man in the UK.
Dave.
Posted on Nov 09, 2008
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
Rock o la jukebox wont pick up record to play
I actually have the answer to your problem, there are 3 things, if you make a selection and it goes to it but wont grab it, that means the gripper motor is bad.
If your carousel keeps spinning I think its like the wurlitzers, your index light or orbital reader bulb is bad, 2 names but same bulb, depends on who your talking too,
and the last thing it might be is yes your safety switch, happens when someone grabs the arm it can be moved and then your dead in the water, the cd models also have an on & off swtich so check that too. Hope it helps
Feb 20, 2012 | Audio Players & Recorders
Hello, I have a problem with WURLITZER 1015 OMT CD 100D. The arm go to pick up the CD, but returns in the same time as it lock the cd in the gripper.Result is the CD is supported on two points instead of 3...
The carousel is locked in position by the latch at the front (about 6 oclock). If the gripper isn't exactly in line with the cd then you need to adjust the latch a bit.
Nov 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm frozen w/ one digit flashing 8 then E w/o top of E
At the far side of the white nylon gears at the base of the gripper arm is a small white 'duck bill' bracket, which clicks a microswitch when the gripper is over the carousel. When it breaks or comes loose it fails to click the microswitch and the arm doesnt stop.
Dave F.
Mar 11, 2009 | Wurlitzer Jukebox CD Player
JUKEBOX WAS SHUT OFF WITHOUT REJECTING ALL THE RECORDS.
What exactly do you mean by "shut off before all the 45's were rejected" ? The mech only load one record at a time, either from the left or right side of the carousel. If the power was shut off before a record unloaded from the turntable, you can manually return the mech to the start position. Do this by getting in to the back of the juke. on the upper right, near the top of the deck, there is a motor. There should be a little white gear coming from the bottom of it. I am assuming if you look in the middle of the mech, you will see a cam with a lobe on one side of it. Turning the white gear will advance the mech adn turn the cam counter clockwise. As the lobe on the cam nears the front of the mech, the record lifting arms should pull down clear of the carousel and return the record to the carousel. Stop turning the gear when the lobe of the cam has driven the lifting arms downward. Inspect your pin bank and push down any "popped" pins. This will prevent the juke from trying to start when you turn it back on.
Hope this helps
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
May 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
251 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
