Question about Ricoh Office Equipment & Supplies
Paper won't come all the way up, stops at 1st level
  • shellyc511 Nov 05, 2008
    It's the 2210L
    Problem Solver:
  • 10 Answers
What Model Fax have you got?
If it is the 1800, it needs a new Seperation pad.
Posted on Nov 05, 2008
Jammed paper shredder motor stopped won't start
Had this sort of thing happen to me also; sort of. Did you check to see if the shredded paper level alarm has been triggered in the pull-out catch area? Sometimes it forms a pile that trips the alarm before the catch is full. Sounds simple, but check it out. Also check to make sure it's plugged in! I've done that several times, even to the point of calling for help! Did you know the technical help desk always asks if the machine is plugged in first!
Feb 20, 2013 | Office Equipment & Supplies
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
We just moved, and now that I've set the printer up in a new location, the paper won't feed at all. I removed the cartridge and wipped the paper feeder with alcohol still no luck
When you move the printer normally somethings will brake and get stuck. But 1st things 1st did you check if the tray lifts to take the paper? or try to take the paper atleast? if not then you can try to wiggle the printer a little and you should fine some thing being stuck come out and the printer work well again.
Jul 06, 2011 | Samsung ML 2010 Laser Printer
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
MPC4000 jamming when copying double-sided color paper. Is there a fix?
1st question is does it jam on regular plain white paper dbl sided ? if yes it depends on where it jams and what the service jam code is, if no then how thick of color paper is it ( is it within the copier specs ? ). If the paper is within the specs you should set either the paper tray or bypass tray for the correct paper weight in user tools, because it does two things : 1 it slows down the copier speed and 2nd it increases the heat level.
Apr 14, 2010 | Ricoh 4506 Copier
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
There 3 light on the printer that able to indicate to user when problem occur.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Paper pickup
Does it move the paper at all? If you have more than 2 drawers do other drawers work? Does bypass tray work for feeding paper? If paper does move does it always stop at same place?
Jul 03, 2009 | Canon Office Equipment & Supplies
Won't shift from 2nd. when i start from a complete stop.
No engine problems? Then the transmission filter is clogged, most likely its never been changed and the fluid has lost its lubricity. Different transmissions show different symptoms. If you take it to a shop it will get expensive. They'll probably suggest ether changing the transmission control module (TCM) or transmission itself. Just give it a tune-up. Before anything check the transmission fluid level. Make sure its not low, if it is let me know to help you find the leak. If you have a leak you'll have to fix that first. No matter what you still have to give it a tune-up.
Jun 18, 2009 | 1991 Dodge Caravan
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
