Question about Toshiba Satellite A105 Notebook
Sat A105 starts normally, but after WiFi antenna starts, the screen blanks !
Satellite A105 starts normally, but then when i slide the WiFi button, the screen blanks!!
  • Toshiba Master
  • 4,806 Answers
Try reinstalling the wifi drivers without the software
Posted on Nov 14, 2008
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
Are all Satellite A105 15.4" screens the same? I
The LCD assembly will have a part number either on a paper sticker or printed on some empty real estate. Check for one that matches the structure of part number(s) listed on eBay.
You can start with the link below:
Toshiba Satellite A105 LCDs
Aug 07, 2011 | Toshiba Satellite A105-S2716 Notebook
Where is the wireless switch on this dam thing
Some laptops don't have a mechanical switch for wifi. But just try to look around the back portion or the front or sides of your laptop. Wifi switches are slide type. You just slide it to toggle on and off.
However, newer laptops have no mechanical switches. To turn your wifi on/off, just hold down the FN key and press the Function Key (F1 to F12) where you can see the wifi logo like this: )))
In my unit, it is FN+F10
Try it out.
May 22, 2010 | Acer Aspire One PC Notebook
Hi, I have a Toshiba Satellite A105-S4254 when I boot the laptop it goes to the windows xp screen, after that right before the starting up screen, it goes to a blank black screen with the mouse cursor, but...
try restoring this unit to an earlier time
in restore function is a calandar check which things were updated last time
go to start
all programs
accessories
system tools
restore
heres the restore function
Apr 18, 2010 | Toshiba Satellite A105-S4254 Notebook
Ay to be sat nav
try charging battery hooked up to the computer
there also is a lock on the start button
slide halve way instead of all the way over
May 30, 2009 | Tomtom One XL GPS Receiver
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
On my toshiba a105 4284
mayneed to reinstall operating or run system restore. there are files missing.
Apr 15, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
