Question about Frigidaire GLGH1642DS Front Load Stacked Washer / Dryer
Frigidaire Stackable Front Loader Washer
My friend is having a problem with her front loading stackable full-size washing machine. It is only 1 1/2 years old and should still be under warranty but the dealer said it wasn't. The washer will fill only 1/4 of the way, then immediately start draining. No agitating or anything. I feel that there should be a simple solution. Can you help? Thanks in advance! Jane
  • mei2005usa Jan 14, 2009
    My Frigidaire Stackable Front Loader Washer also only fil water to less than 1/4 level and started spinning. It's like washing the clothes without enough water. The clothes are just wet for spinning around inside the washer. For the rinse cysle, it's the same effect.
    President:
  • 878 Answers
Jane, check to make sure that the drain hose has a air gap in the drain. Sometimes you will get a siphoning effect if you don't have the gap or it is pushed down to far in the drain. If this is not your problem, it's probably a timer issue...Catriver..post back
Posted on Oct 04, 2006
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer Seal ripped door seal
Yes. Because all front load and or stacked machines are bad! It is called Planned obsolescent. Meaning, it is normal for a new machine to break and become obsolete! These seals on the front loaders can be Expensive around $100 dollars...Sorry
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Feb 19, 2014 | Maytag Washing Machines
Six-year-old Frigidaire stackable front-loading washing machine turns on, fills up with water, but makes a loud noise during the spin cycle?
If it is a banging or uneven sound, your tub and unit is not balanced any further. The tub could be off of the pulley/bearing supports and needs professional attention.
Aug 15, 2012 | Washing Machines
The water in my stackable washer and dryer wont drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Wsxh208fww front load stackable washer, spin cycle won't work
It most likely has a bad door safty switch. This goes out and the cycles will not run.
Jun 15, 2009 | GE WSXH208A Front Load Washer
A friend wants to know were the model number is and load size
Inside the lid will have the model # and capacity. If not - a tag right where the hoses connect is a likely spot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2009 | Kenmore Washing Machines
Frigidaire GLGH1642DS Front Load Stacked Washer / Dryer Logo
221 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
