Question about HP Photosmart 2410 All-In-One InkJet Printer
Ink problem When I try to print the printer prints a blank page. I have replaced my ink cartiidge but that didn't solve my problem.
  • StudioGuy Nov 05, 2008
    I have a Mac OSX 10.4. Let me also say that I know that the printer is working because if I go into the printer settings and mess with the color settings and darkness settings it will print properly. But it takes a few minutes to print one page and it seems to use a lot of ink. I am assuming because of the settings I changed. I have also noticed that when I remove the ink cartridge there is some excess ink below the cartridge, like it might be leaking or something.
    I also forgot to mention that the color ink seems to be working fine.
I would like to know what operating system and computer type you have, please. This will help me to find the problem, and hopefully fix it! :-)
Posted on Nov 04, 2008
HELP!!! Designjet T610 Prints Blank Pages. When printing multiple pages the printer start to print blank pages after the 1st or 2nd page. What can I do?
Go to Staples in your area or try the staples.com website you might be able to get the same kind of printer or better. the people at Staples are friendly and they will be able to assist you they know a lot about these kind of things such as printers, and computers, and tablets and stuff. See if they can help you better.
Jul 10, 2015 | HP Designjet T610 InkJet Printer
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
I have just replaced my ink cartridges, but now it wont print anything even though it makes the right noises. it whirs and takes the time it would to print something, but the page appears blank.
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink. The printing device consists of a print head and cartridges with ink. When you change the cartridges that does not mean you change the print head, like in some other models. Now you can choose the "head cleaning" option from the printer settings a couple of time. If this does not help you have two options - to get the device to service center or buy a new one. The second option is the cheaper one I suppose. And remember for inkjet printers you must print at least 1 page per week to keep head from clogging with ink. Hope this helps Alex
Sep 11, 2011 | Epson STYLUS CX5900 Printer
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
Blank lines through my text or graphics several times per page...help!
Here's the starting point for any print quality issues. The subject starts pretty broad, but if you follow the instructions, you should be able to solve your problem.
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Deskjet 722c appears to print but the page is blank. New toner cartridges have been installed
If the clean test page shows streaked or broken colors, the printer or cartridges are not functioning properly. Note that HP cannot guarantee the quality of refilled or remanufactured cartridges. Follow the steps below to solve the problem:
  1. Remove and reseat the cartridges. Try printing again.
  2. Check ink levels, and if a cartridge is low on ink or out of ink, replace it and try printing again.
  3. Clean the cartridges. Depending on what printer you have, you can either print another clean test page or run a cleaning utility. Check your User's Guide for instructions. Try printing again.
  4. Clean the contacts, then try printing again. Click here to see how .
  5. Align or calibrate your cartridges (depending on what printer you have). Check your User's Guide for instructions.
  6. If none of the steps above have helped, clean the nozzle plate manually. Click here to see how .
  7. If the problem still has not been solved, replace the cartridges or service the printer. Click here to see how to decide which to do .
Feb 13, 2010 | HP DeskJet 722c InkJet Printer
Page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Jun 23, 2009 | Dell Inkjet 720 Printer
Printing Blank Pages
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
Nov 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP officejet D145
Does it happen when you try to print from an application - like Microsoft Word or even Notepad? How about printing a test page from the properties page of the printer?
Sounds like either the printheads are clogged or there is no ink at all. Try running a few cleaning cycles. If you're sure you have ink, then try cleaning or replacing the printheads.
Dec 31, 2007 | HP OfficeJet d145 InkJet Printer
Printing inkless printing
Gecko17 How old is your cartridge? is there is enought ink to print your document? If so then... Take out the cartridge carefully from your printer without touching any contact points, heads etc. Clean the head's of your printer cartridge carefully by using head cleaner fluid. After that, reinstall your cartrige and please try to print again. If this deosn't solve your problems, you may need to replace your cartridge with new one. thanks
Aug 30, 2007 | Lexmark Z600 InkJet Printer
HP Photosmart 2410 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
