Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung HLN5065W The screen has become somewhat out of focus, with red edges around dark areas of the picture.
  • rmark778 Nov 04, 2008
    My understanding is that DLP TVs do not have convergence contols.
    Genius:
  • 2,920 Answers
Have the tv reconverged
Posted on Nov 04, 2008
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
Picture brightens then darkens
Trying with a DVD will rule the tuners in the set in or out and also suggest a setting in the set or a box if used is causing this issue.
Nov 03, 2012 | Samsung LN32C350 32 in. TV
Dark Band on Samsung projection TV
most likely optical engine issue----bad light engine.
Aug 27, 2012 | Samsung BP96-01073A E-Series Replacement...
I can't find object in dark. Though the camera should identify (may be red ray focus) the object to take snap. In manually I set up all the possible way but in vain. Could you pls. give me a set up...
Yes, the camera does attempt to illuminate the area to allow autofocus, but the darker it is, the harder it is for autofocus to work. This is a problem even with high-end SLRs.
Usually the center focus point is the strongest and focusing works best when there is a strong vertical line.
There isn't a complete solution, but you there are a couple of work-arounds If you have a camera with manual focus, then use manual focus Point the center focus point on an edge, depress the shutter button 1/2 way to focus, then re-frame the picture.
Mar 03, 2011 | Cameras
I have a Samsung CRT slimfit that I bought in 2006. It has worked splendidly until about 4 months ago and suddenly I have started to notice the edges of the screen about 2-3 inches on both sides have...
In my experience from doing Samsung's warranty work on slimfit sets, they have issues with picture tubes causing problems on the circuit boards. Many times I would replace a board only to have it fail a short time later. The wide crt draws a large amount of current and many have purity (discoloration around edges) problems. I would suggest you try contacting samsung to see if any recall exhists on these and if that doesn't work I wish you luck having it repaired properly for under 275.00
May 21, 2008 | Samsung Televison & Video
Whirring noise. No other problems.
Sounds like you have a noisy color wheel. Very common on all Samsung DLP`s. The part # is BP96-00250A for model HLN5065W.
Oct 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
