Question about HP PSC 1210 All-In-One InkJet Printer
Paper will not feed.
I go to print.. a normal rolling sound is heard, then after a few seconds a louder and distinct sound of the meccanism that has always (until now) sucked the paper in. Nothing happens exept a message on screen saying i have no paper, and the 'check paper' light flashes on the psc 1210. Any help?
  • 1 more comment
  • uratia
    uratia Nov 04, 2008
    Hi Alex, thanks for the advise. Unfortunately none of the solutions indicated solved the problem. Paper was preloaded before print, the printer was turned on and off while loaded and there is no sign of obstuction of any kind. I read a solution written by Viper_xp > http://www.fixya.com/support/r989244-pri... > who states that there is a spring that can be 'moved' in order to provide more tension. I located the spring on my HP psc 1210, but I have no idea on HOW to actually manipulate it, it's kind of out of reach...
  • yvonne harrison Nov 11, 2008
    Paper won't feed but a sound of the printer attempting is heard.
  • robfruge Nov 13, 2008
    Im reading the same problem Im having. And it was just all of a sudden thing to happen. I took off the rear panel an noticed that it doesn't look like the feed wheel/bar is moving eventhough I hear the motor running. Should I open the printer more to see how its connected to the motor that it may be something fixable?
    Scholar:
  • 31 Answers
Hi, my name is Alex and I am here to help solve your problem regarding your printer.
Please make sure the paper is preloaded into the printer before selecting print. Also please try turning the printer off and then turn it back on and make sure the paper is loaded when doing this. This is normally a common problem so nothing to be worried about.
One other thing to do, please check inside the printer and make sure no paper is trapped in there, there shouldnt be as you would get the paper jammed window on your screen but when little bits of paper get left inside the printer, when the new paper goes to get fed inside the printer, it doesnt go down properly.
I hope this makes sense to you. Please let me know if you experience any more problems.
Posted on Nov 04, 2008
Reading on door OF
Teresa, The fridge is in a retailers demo mode and here is what you do to reset it to normal operation:
Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
  • At the top of the door frame: Simultaneously press and hold the "Power Freeze" and "Freezer" buttons until you hear a distinctively different chime sound and the temperatures for the fridge and freezer are both displayed.
  • Note: If the temperature is displayed, but then "OF OF" reappears a few seconds later, Cooling Off mode was not disabled. Repeat the actions above, and be sure to press and hold the buttons at the exact same time until the distinctive chime sound is heard and both temperatures are displayed.
Apr 11, 2014 | Samsung RF265AA Bottom Freezer French Door...
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Epson stylus 4800 pro. It was printing dye sub 3 out of 4 colors. I cleaned the capping station and put simple green under the heads to soak them, now it prints nothing not even on test print it says the...
most of the time after performing maintenance after receiving an error msg the error messages have to be reset to tell the printer that it can print again
this is 4 procedures depending on your problem one of them should fix it
  1. Turn off your printer, ensuring that the print head is at it’s home location and locked in place as normal;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1;
Procedure 2
  6. Allow printer to complete it’s processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 4 - Cheat with Software Reset Methods! There is a software reset method that can be used to reset ink levels. It is recommended to use in Epson service centers. Each printer model has specifyed service (adjustment) program which has such option like Reset Protection Counter when you need to reset the value of Wate Ink Counter. You can learn more about software reset method at this link: About Service Programs.
This programs can be used to reset a number of counters in the printer, etc. Please note that CIS users should probably steer clear of any resetting of cartridge ink levels in the printer, and you will probably need to look for the ‘Protection Counter’. Due to the risks of resetting this protection counter, it may be preferable to use the software once to reset the counter, then uninstall it so you do not inadvertently reset the counter more than once.
According to it’s own readouts, it did reset the ‘protection’ counter... but pretty much did so of it’s own accord. It then seemed to interfere with printing! However, the access to advanced cleaning function control etc looks useful. Nevertheless - use with caution as per the notes above!
hope this helps
Robb
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Dec 09, 2008 | Office Equipment & Supplies
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
HP PSC 1210 All-In-One InkJet Printer Logo
113 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
