Question about HP DesignJet 500ps (42 in.) InkJet Printer
Code Error 79:04, 86:01 y 81:01
Hi, Mi HP DesignJet 500 does not work. At first the error were the printheads, it said Error Select Replace Printheads and the black one was marked, but it was stocked to changed them, so we turn it off. Weeks later we continue turning it on and off and the error code changed 3 times this were the error codes 81:01, 86:01 and 79:04. The 3 codes appear one at a time every time we turn it on. Can somebody help me??
  • crossbow26 Mar 31, 2009
    My client's recently acquired 500PS had a damaged carriage cable. I replaced that, lubed the rails, cleaned the encoder and installed new print heads. Everything tested great and worked for about 4 months. Now the printed page is "blurry" from the right side (bottom margin) for about 8 inches up the page, I replaced the spent Yellow Print head (0303 error) but continued to get the same error – and random 86:01, 79:04 and 74:01 errors.
    A Firmware and Formatter Firmware update fixed the random errors and permitted the plotter to "accept" the new print head for 2 pages – still blurry, then it posted a new error: ”0330 Print head Faulty" which will not clear. I've cleaned the print head contacts, the flex-strip contacts and removed/cleaned the other print heads (as prescribed in the SM).
    Now at every restart the yellow still displays the 0330 error (which is not in the service manual), and the other print heads each display a different "soft" print head error (i.e. out of warranty, expired, empty, etc.) at each startup, or "print head replace" cycle. Only the Yellow and one other print head at a time post errors, but each power/replace cycle posts a different error, or an error for a different print head.
    I'm suspecting either the carriage assembly or formatter board, but not sure which is the most likely culprit.
    Any help would be greatly appreciated.
    Problem Solver:
  • 8 Answers
79:04: Check the usage and expiry dates on the printheads to start with. Have you refilled them with third-party ink? Even if you have before and haven't gotten this message, your printer might have just picked up on it. Particularily, if you have recently done a firmware upgrade.
Try taking out your printheads and see if it boots up. If it does, then there is a good chance that it's a printhead related issue. Once again, check the expiry dates.
If the error persists, try to re-seat your formatter if you have one.
Try restarting the printer with no printheads or cartridges or media and insert them one by one.
If the error comes up with one specific printhead or cartridge, you may want to replace it, expired or not. And replace it with an HP product designed for your specific printer.
Damage done by third-party products will not be covered by original warranty, or extended.
Final suggestion, is look at the conteacts on the back of the printheads. Are they dirty with ink or grime? What about the contacts in the printer. If they are, I would suggest using a SLIGHTLY damp coffee filter and gently wiping up and down until they are clean. DO NOT wipe horizontally or in circles. It may cause scratches to the contacts which could further damage them. Wipe them vertically with a DRY coffee filter, or allow them to completely air dry before re-inserting them. Before you re-insert them, reboot the printer with nothing in it, and insert them one by one.
For any further assistance, I suggest phoning HP Technical Support.
1-800-474-6836
Best of luck.
Posted on Dec 15, 2008
Hi have hp z2100 when the plotter go to cut the paper to the left is stock befor go to cut the paper
Posted on Oct 05, 2012
Hp call support
Posted on Apr 09, 2011
HP Designjet 500 24-in Roll Printer error message 2110
Service Station failure. The possible cause could be:
The steps counted by the Service Station motor are not consistent with the expected length of the current movement.
The Aerosol Fan has reached its maximum current limit.
The Service Station motor has shutdown because of blockage.
8x8.gif Corrective Action 8x8.gif 8x8.gif Try the following:
Remove ALL the Printheads and clean the flex contacts on the Printheads and in the Carriage Assembly.
Replace ALL the Printheads.
Replace the Service Station/Aerosol Fan Assembly
Apr 05, 2010 | HP DesignJet 500 InkJet Printer
Designjet 1050C system error 060308 00000008
Problem
Description:
One of the Printheads has an Internal Electrical Problem.
Corrective Action: Try the following:
n Remove all the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly (Refer to Chapter 2).
n Perform the Electronic Systems Test þ Page 4-5.
n Make sure that the Trailing Cable is connected correctly.
n Replace the Trailing Cable þ Page 8-39.
n Replace the Carriage Assembly þ Page 8-44.
n If the error code continues, replace the Electronics Module þ
Page 8-25.
WARNING Only replace one component at a time and check if the error has
gone before replacing another component. Using this procedure
you will be able to determine exactly which component failed.
Jan 11, 2010 | HP DesignJet 1050c InkJet Printer
Hp designjet 500 plus
Problem Description: Carriage-Axis shutdown. Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
1) Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
2) The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
3) Perform the Carriage Movement test
Aug 19, 2009 | HP DesignJet 500 InkJet Printer
HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Aug 17, 2009 | HP DesignJet 1055cm InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
System Error 060308000008 on HP Designjet 1050C plus
that error show a problem with the pintheads
Printheads and in the Carriage Assembly, if that dont solve the problem change printheads, if after that have the same problem call HP, was a hardware error.
Apr 30, 2009 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Taking Longer than normal to Prepare PrintHeads
remove the printheads and give them a wipe with a damp cloth, the ink sometimes dries on the head preventing it from registering as working
Jan 24, 2009 | HP DesignJet 5500PS InkJet Printer
Error 0c0030 00000088
That error indicates that the drop detector is not working. If a Print Quality test shows that the pens are working and nothing is blocking the inside of the drop detector, perform the Service Station calibration. If the error doesn't clear, then replace the detector assembly.
Sep 10, 2008 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 500ps (42 in.) InkJet Printer Logo
4,808 people viewed this question
Ben Johnson
