Question about HP Computers & Internet
My charger is plugged into my laptop but it isn't charging my laptop up, it all seems fine and plugged in proberly but still isn't charging. It recently was sharply pulled out of the laptop and I don't know whether this has caused the problem.
    Problem Solver:
  • 15 Answers
Try to charge your laptop while its closed....if it work, you need to change your charger...thanks
Posted on Nov 05, 2008
Not charging when charger is plugged in.
if the battery is above 90 percent this is normal , if it isn`t then you charger - or nb plug malfunctioned and is not recognized as genuine hp charger and will only power on to prevent damage to battery. TRY NEW CHARGER
Feb 26, 2014 | HP EliteBook 6930p Notebook PC
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
Powercord replacement
please explain further.. do you mean your laptops power adapter cord?
thanks for using fixya
Nov 10, 2011 | IBM ThinkPad 380ED
I have an Acer Aspire One ZG5. After a minor fall it won't charge anymore unless i push it in the jack with serious pressure. I know the charger isn't causing this as it is brand new and was...
The power jack has a crack solder connection on the motherboard, the only way to fix this you must take the laptop apart in order to address the issue, this task requires someone with high specialty skills to pull it off and be able to use a soldering iron to fix the problem.
Sep 11, 2011 | Acer Computers & Internet
My charger is plugged in to my MSI U130 netbook and in to the wall but is not charging at all. It isn't coming up with the little image to show the charger is plugged in, I have tried plugging the...
There are two very common faults that often cause this.
One is a damaged cord on the charger.
The other is a damaged connector on the laptop.
You will need a volt/ohm meter to test the charger. If you don't have one perhaps a friend does?
If you think you may have use for one inexpensive models are available and are fine for simple jobs and occasional use.
The charger's output voltage will be listed on the charger body. Look for something like:
OUTPUT: +19V 2000mA
For your purposes all you need to know is, is the charger putting out the proper voltage and is it steady?
If the charger is working then it is very likely the connector on the laptop.
These are not difficult to fix if you have experience repairing laptops.
Most computer repair people do this all the time for a reasonable set fee.
Hope this helps
Jul 03, 2011 | Computers & Internet
Put to high of voltage cord on to charge it and now it does not turn on
you have most proberly blown the laptop because if the amps are higher on the other charger then on laptop
Mar 28, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My blackberry isn`t charging, i`ve plugged it in and nothings happening, when i plug it into my computer it has a lightning symbol by it but im not sure what it means?
does the phone charge when connected to the computer? The lightning icon means it is connected to power and is charging. Try another charger, it seems like your charger is the problem, not the phone.
Dec 15, 2009 | RIM BlackBerry 7290
Computers & Internet Logo
143 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
