Question about Sharp 27C-240 27" TV
TV distorted colors
I have a sharp 27" standard tv that just started to have bluish spots showing up in the corners. How do I fix that?
    Sergeant:
  • 337 Answers
It needs to be demagnetize but the tv has it's own demagnetizer and it does it when you turn the set on,you need to unplug the set from the wall for about 15 minutes and then plug it back in and turn it on and the splahes should go away,if you have placed speakers on top of the set or in its sides remove them because they will cause this problem or if you have move the tv while it was on or the set was dropped.Let us know what you find.
Posted on Oct 04, 2006
How to fix my sharp 27rs50 tv color its showing green
Loose solder terminal/s at its video output circuit. This circuit can be located at the car, attached to the back of the CRT.
Gopakumar Gopalan Google
May 08, 2014 | Sharp 27R-S50 27" TV
Ok so i have the Mitsubishi WS-55807 TV and when i turn it on in the corners and around the screan the color gets distorted showing the same image twice or 3 times like its projection lights are off...
If you're good at soldering, Part #s STK392-570 may both be bad. If you tap on it and it works. Pull out the board with the 2 chips, (mark all the connectors) with the TV off. Replace these. You can find them on Ebay (at least to see what they look like). First go to the spot under the board where both of them are and resolder each pin avoiding bridges. Also resolder all the spots that you see the plugs you labeled at. With the TV on using one hand, with one hand in your pocket, carefully physically feel the metal heat sink the parts are connected to. If they are cold, you probably have bad fuses. They are usually beige. With the T.V. off and a meter, check these for continuity.
Jun 16, 2011 | Mitsubishi WS-55807 TV
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
Screen Spots
move your streo speakers or any thing w/magnet
Jul 06, 2008 | RCA F32650 32" TV
Color problem
is there a speaker ( other than built in ) near the tv? ( if so, move speaker away from tv.
Dec 13, 2007 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Brown spot in picture
you might have a couple of dry joints, and you might also have a bad PTC inside that degauses the screen when tv starts up. Please try another good tech for a service. Patrick
Aug 27, 2007 | Toshiba 27DF46 27" TV
Sony Trinitron shows distorted hexagon off color pattern in picture
Yes sure your tv can be fixed just call a tech and outline the problem.your tv has losted for a long time after repair it could last you a very long time congrats for keeping a tv for such a long time.
Apr 03, 2007 | Sony KV-27S42 27" TV
Sharp 27C-240 27" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
