HP Compaq nc6320 PC Notebook
Problem for HP Compaq nc6320 PC Notebook
Can't reinstall xp pro on my hp compaq nc6320
By stephmouz on Oct 04, 2006
i have a laptop hp compaq nc6320 that i want to customize.
i want to install XP pro but during the copy of files, the system diplay a message wich says that "windows cannot copy the file". when a change the CD Rom, the computer copy all files but after i receive a message wich says that windows cannot detect the hard drive and the installation stopped.
i really want to install properly and remove all HP's settings from the computer.
can someone help ?
stephane
Same Problem
Jun 13, 2008
-   i cant install windows xp hard drive not dedecting-   Guest
Mar 28, 2008
-   same problem
-   zohour
Jan 29, 2008
-   can't detect the HP hard drive-   randel
Dec 11, 2007
-   I have HP core duo with vista,I want to install xp pro and it tells me there is no Hard drive.Please I need Solution now.Thank you-   kixxed
Best Solution
posted on Oct 25, 2006
Very Helpful)
Burnsy30
Rank: Apprentice
Rating: 100%, 47 votes
Stephane,
I ran into the same problem after wiping out my Compaq nc6320 and trying to install XP Pro. The fix is to disable SATA Native mode. To do this:
Enter F10 Setup then System Configuration>Device Configurations>SATA Native Mode and disable it, save the changes and now you should be able to install XP Pro. Remember, when I did this the drive was blank, I don't know if that makes a difference or not.
Best of luck!
Bryan
P.S.
If you want to enable SATA native mode after you have installed XP Pro check out this link:
http://forums1.itrc.hp.com/service/forum...
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #2
posted on Sep 21, 2008
Very Helpful)
upontheroof_
Rank: Apprentice
Rating: 100%, 6 votes
FIRST OF ALL MY ENGLISH IS VERY SORRY BUT I HOPE YOU UNDERSTAND THIS.
FOR THE ----HP COMPAQ nc6320
1-TURN IT ON, IN THIS PROSESS PRESS -F10- WHEN PRONTED.
2-YOU WILL BE GETTING INTO THE SYSTEM -BIOS. OR SYSTEM SET UP.
3-ONCE YOU'RE THERE YOU WILL SEE THE MENU'S SCREEN AS FOLLOWS---
FILE- SECURITY- DIAGNOSTICS- SYSTEM CONFIGURATION.
USING YOUR ARROWS ON THE KEYBOARD GO TO THE LAST ONE AND ON THE PULL
DOWN MENU GO DOWN TO- DEVICE CONFIGURATION, PRESS ENTER YOU 'LL GET
ANOTHER MENU, AGAIN USE ARROW KEYS AND GO DOWN TO WHERE IT SAYS-
SATA NATIVE MODE- USING YOUR ARROW KEY AGAIN SIDE WAYS LEAVE IT ON
DISABLE MODE. THEN PRESS - F10- TO ACCEPT THE CHANGES, IT 'LL TAKE YOU BACK TO ANOTHER WINDOW TO - SAVE CHANGES AND EXIT- PRESS -F10 AGAIN AND YOU SHOULD BE GOOD TO INSTALL (XP AND THE OTHER XP WITH MAKEUP...vista)
THANKS,
JAVI HERDEZZ68
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #3
posted on Oct 04, 2006
Helpful)
dugiehowsa
Rank: Wiz
Rating: 77%, 871 votes
Sounds like the hard drive may be having problems. Download this bootable CD and see if any of the hard drive utilities indicate anything. You may have to replace the hard drive or cable that connects the hard drive to the motherboard.
http://www.ultimatebootcd.com/
Was this helpful?
Yes
No
Solution #4
posted on Jul 13, 2009
Somewhat Helpful)
nkkandy2002
Rank: Apprentice
Rating: 75%, 1 votes
XP was eintalled on my PC but I'vent sound on it, i've no the software for all device
can i have solution?
Was this helpful?
Yes
No
Popular Solutions for HP Compaq nc6320 PC Notebook
Questions and Unsolved Problems for HP Compaq nc6320 PC Notebook
Do you recommend HP Compaq nc6320 PC Notebook?
Answer
Answer
Why have I lost my wireless connection? I have a wireless and a landline router. I had set up... (More)
Answer
how to reset comp to original settings i want to use alt and whatever f11 or f12 or whatever it is i... (More)
Answer
A wire within the dc power cord has broken near the laptop input jack. In cutting off the old plug I... (More)
Answer
battery for aspire 9300. 11.1 or 14.8 can either on be used without harm. is 14.8 an upgrade that... (More)
Answer
Disk failed and was replaced. When loading Vista can see the disk format partition etc, but when... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Compaq nc6320 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
