Sony trinitron tv kv-32s42 has no volume
Hi I have a sony trinitron tv kv-32s42 and it all of a sudden has no volume.
There is a little noise in the background that goes away when I mute it . Please Help
    Genius:
  • 1,550 Answers
Change the audio amplifier Ic
Posted on Nov 04, 2008
How can I turn the screen voltage up?
from description you are on the right track--screen con inside will either be on the crt circuit board or on the high voltage transformer, on or the other--lots of the older Sony sets when the picture tube gets weaker need this done.
Dec 15, 2012 | Sony KV-32S42 32" TV
Sony tv Kv-32s42 flashing stand by light non stop, sound but not picture
You probably took out the Horizontal Output. A repair like this is between 150-195 dollars.
Jun 06, 2011 | Sony KV-32S42 32" TV
My remote worked fine, but suddenly won't work at all. TV is older Sony Wega 24" Trinitron (KV-24FS100). The satellite remote will change the channels, cause it's using the box, but it won't control...
Could be the IR receiver in the TV.
Make sure nothing is in front of the TV that would block the IR from receiving commands from the remote, I've seen customers put VHS tapes on the front of their TV that caused the remote to not to work.
Good luck
N Sabre
Nov 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My sony Trinitron KV-32S42 keeps blinking on and off
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
Nov 11, 2008 | Sony KV-32S42 32" TV
Sony trinitron 29 inch kv j29mn
Possibly dry solder joints or faulty coupling capacitors around the audio section.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Picture Problem
Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron Model KV 20M20
You may have a bad H board which is the board that has the voulme/channel buttons on it. You may want to have a Sony asc give you an estimate to repair. Good Luck
Dec 04, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Grand Wega 50" LCD
What is model no of your tv, I think, there maybe a modification for it
capital98
Nov 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound Problem
There's a possibility that you may be experiencing problems with the audio output IC -IC404 - All serial numbers produced until July 2003 might use one of these defective IC's. So if your set was manufactured before this date, that is probably the culprit. If not, and you have it connected to a cable box that has its own volume control, it could be that its volume is turned down and by turning up the TV's volume too high that you are getting this distortion. Hope that helps.
Jan 20, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Televison & Video Logo
445 people viewed this question
Top Televison & Video Experts
