Question about Toshiba 50HX70 50" Rear Projection Television
Mine has a sound problem. when i turn it on the sound is just set at a very low level.but after some time it abrumptly comes highy. i was suspecting dry joints but still the problem exists.i also tried to change the speaker but that doesnt solve the problem. i will appreciate if this problem will be sorted out. thanks syan@chanco.unima.mw ,cmbuto@yahoo.com ,stonald2000@yahoo.com
    Problem Solver:
  • 11 Answers
Some toshibas use an mtx module if yours is one of these take the cover off there will be a little board inside it will look dark that is your sound ic if yours is like this that should fix it
Posted on Oct 16, 2007
SOURCE:
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
HOW CAN I IMPROVE SOUND LEVEL ON MY LAPTOP WHEN STREAMING TV SHOWS FROM INTERNET?
Buy a set of speakers that plug into your usb port. Try Tiger Direct at: http://www.tigerdirect.com
When the site comes up just type: USB Speakers for Laptop in the search box and type GO. When the results are returned sort them by Price Low to High. They are as low as $9.99.
Below is a link to the speakers directly.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=usb%20speakers%20for%20laptop&sort=1&recs=10
May 20, 2012 | Computers & Internet
I have a light on my '93 Volvo 240 that comes on each time I use the brakes. The light is in the lower right corner and looks simething like an upside down light bulb.
This sounds like an information sign that lets you know your brake fluid level is low in master resesivoir. At a point were you push the brake pedal and drops the level ane sensor comes on. Sudden stop and go and on turn driving cane do this if level ids low.
Feb 11, 2011 | 1993 Volvo 240
Engine is over heating unless you turn on defroster, then the fans come on , however interior temp switch , appears not to be working, because it continues to blow cold air into the vehicle,
May just be low coolant level. Remove rad cap, or if none, coolant return bottle cap, and start engine and run heater while doing this. Now pay attention to coolant level and add as needed to top up the system. Let it run with cap off until rad fan comes on and off, 2 or 3 times and keep adding coolant if level goes down. Keep an eye on temperature gauge while doing this. It almost sounds like your coolant got low, or is low, and your heater has an airlock. Once coolant circulates back through heater and level is correct, see what happens.
Nov 03, 2010 | 2000 Ford Taurus
My phone has a very low sound that i cannot even hear it when it is in my pocket.It does not even vibrate in such a way that i can detect it.
you can increase the sound level,
the sound level for tones, speaker fone, etc,
can be increase even then if it is at max (level 4)
you still can do it,
just follows the instructions!
**************** HERE WE GO **************
Enter the following code:
*#8999*8378#
(You'll be shown menu, then ...)
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
There will you see a number.
there are five (5) Melody Levels" of it.
(and currently, you are at level 1 and after
pressing the "save" button, you will move to
level 2 and so on .........................)
you have to change the values of all the levels.
and as the resultant, it will give increase the
melody sound!, your tones will more louder,
even more louder then the max. ringing volume.
the level wise numbers are: (as its my setting :-) )
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
you even can make your own combinations of level wise
sounding numbers that can change the sound level!.
if your combination cause more louder sound level,
then mine,
then do share it with the group! ... :-)
meanwhile, try my figured-out combination!
IF U R SATISFIED PLS VOTE ME
Jan 21, 2010 | Samsung SGH-E370 Cellular Phone
The sound will not turn up on the station. Just plays low. This has hardly been used.Jenne Maag.
Yours may not be the same model as mine is, but mine has a "sound lock" option which for some reason was turned on when i got it. this makes the sound only go up to a certain decibel level.
Jun 18, 2009 | Bose SoundDock digital music system...
Carbies willn't set float level,right floods,left sets to low
I don't know if its any help but I've fixed my Honda with similar problem. It turns out I reassembled the rich carbys air cut off valve incorrectly. Have you checked yours? I'm wondering if the cut off valves somehow affect the other parts of the carbys. Mine is running sweet now.
Apr 13, 2009 | 2001 kawasaki ER-5
Can't turn up the sound on my Sony Ericsson w300i
what i did i took off the back took the speaker out the wires are barley even touching its easy to fix just check it out mine came undone and it worked for me.
Apr 11, 2009 | Jabra Sony Ericsson W300 / w300i / W550i /...
Crutch pedal presure
The Clutch cable has snapped if is there is no pressure at all in pedal.
or cable ha come out of the link,
Most likely the first option.
Oct 20, 2008 | 2002 Jaguar X-Type
Reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Jan 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Toshiba 50HX70 50" Rear Projection Television Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
