Hi there on my stanton t-80 decks every so often it will only start playing out of one speaker. I've changed the cables and was fine and then it occured again, its not the mixer because i've done checks on that aswell and was just wondering if you could shed some light on this.
    President:
  • 624 Answers
It could be a problem with the cartridge/stylus, since you have eliminated the mixer as a source of the problem, it must be in the turntable. The only place for it to come from would be the stylus/cartridge or the wires in the tone arm, or the pre-amp that those wires go to, or some bad solder in the output circuit being used. My guess would be the cartridge and/or stylus, it is taking much more contact and friction than anything else which could cause it to be intermittent. Please understand that I can only guess at your problem since I do not have the unit in front of me to check myself, so I can not be certain of your problem.
I hope this helps,
Dave
Posted on Nov 04, 2008
How to remote start stanton str8-80
A cable in your turntable , which you connect with your mixer and in the manual it says how to allocate the remote start to a fader / knob.
It's in the manual, except if your ain't able to it.....
May 08, 2014 | Stanton STR8-80 Turntable
Stanton STR8 150 turntable right output not working
Check the connections at the rear of the cartridge. Something may have worked loose while in storage
Oct 02, 2012 | Stanton STR8-150 Turntable
Stanton deck issues
Does decks are too bad build, i gave them away
Jul 23, 2012 | Stanton ST-150 Turntable
Hey guys I purchased the Stanton Str8-80 in 2003 and used it actively for the following 1 or 2 years. Shortly after that, I left it in a corner to collect dust and only recently, I started to use it again....
If the turntable has a belt drive, the belt probably has failed. If direct drive, the motor may have failed. Only a cheap turntable would have rim drive that failed. Your Stanton is not one of them.
Apr 26, 2017 | Stanton STR8-80 Turntable
There's only sound in the left speaker.
when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Jun 24, 2009 | Stanton STR8-30 Turntable
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
No power cable
There is no polarisation on the input lead - It won't hurt the deck if you get it reversed. If you have a shaver lead that fits, that should be fine.
Matt
Apr 16, 2008 | Stanton STR8-60 Turntable
Wont play cds burnt by new computer?
is the files your burninthe same format m8 ie mp3,wma
Dec 09, 2007 | Stanton C.313 CD Player
43 people viewed this question
 Grubhead
Grubhead
