2004 Nissan Altima Logo
Paul Adams Posted on Apr 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nissan Altama Starter Relay electrical problems or a fuse?
Four months ago my battery went dead, I replaced the alternator and bought a new battery. Recently the starter would just barely turn the starter over, but the car would not start. I had the battery charged but shortly the battery went dead and I replaced it only to find I now have no electrical power, zero. I turn on the key and nothing. No dash lights, no horn, no elec windows, headlights, nothing? I had the battery checked at Autozone - it was fully charged, so seems not to again be the alternator issue. Is this a Starter Relay problem ? Or some blown Fuse ? I've check most obvious fuses - all seem intact, so .....??
D Aubrey
Level 3:
  • Nissan Master 1,136 Answers
  • Posted on Apr 09, 2017
D Aubrey
Nissan Master
Level 3:
Answers
1136
Questions
0
Helped
310330
Points
3295
Double check the battery positive connection wiring carefully as it commonly has connection problems when the battery is changed.
5 Related Answers
Anonymous
  • Posted on Sep 12, 2008
SOURCE: Dashboard and tail lights out on 97" Nissan Sentra
I took my pathfinder to U-HAUL and asked them to check the towing lights. There was a pinched wire by my tail light and they cut it and changed it out for me, it was $5. I am so glad that I didnt take it to Nissan. My second step was going to be getting a new dimmer switch..but the guy who worked on my car said that wouldnt be the problem. He also told me that replacing a fuse that kept blowing out was dangerous and after the first time to get it checked out. Learn something new every day!!
Anonymous
  • 491 Answers
  • Posted on Nov 03, 2008
SOURCE: '01 Nissan Xterra won't turn over starter, after trying to start the headlights flash.
starter possibly going bad
hiseyj
Jackson Hisey
  • 99 Answers
  • Posted on Dec 08, 2008
SOURCE: I have a 1998 Nissan
Does the starter crank the engine over? Saying your truck won't start could mean that the starter spins be the engine won't fire. If the starter is not spinning is it at least clicking?
Curt Downs
  • 1779 Answers
  • Posted on Jan 04, 2009
SOURCE: 1992 Nissan Pathfinder charging problems
How long did the 2nd alt. last before it died? The voltage regulator is, I believe, attached to the alternator. Have u had the voltage regulator checked?
Lee Glascock
  • 384 Answers
  • Posted on Apr 01, 2009
SOURCE: dash and tail lights not working in car with no blown fuses
start by the battery twist wire on pos termanal this happen to me on my dodge van bad batt took out speed o meter and tach. replaced batt no speedo no tack.i had to go on a a long trip back home half going up a hill the tach jumped to life then about one hour latter had to make a stop pulling off the freeway slowing down for the stop sign the speedo came on and both have worked ever since. I have talked to a dealer ship there no reset codes for that problem
1helpful
Why no charging on nissan almera ?
So, you did not have the welding done with gas, but with electric arc.
Anytime a person welds on a car with anything electric, the car's owner must disconnect ALL things electrical, or everything may be toasted, as yours is.
The alternator is a self-contained unit, and it either works or doesn't.
The alternator has the voltage regulator inside as a part of it.
I believe you may be needing an ECU, which is the brain of the car, however, because of the damage caused by an uninformed person, your car may never be fixed, because some wires may have shorted out (melted together) inside on of the wire harnesses that are all over your car. I think the best you can hope for is that it runs, and the alternator charges the battery as needed. I think the alternator is supposed to put out about 13.1 volts.
If you look up an ECU on e-bay, you will notice there are repair services who can repair your ECU. I have used them several times, and this has worked well for me.
Sorry.
Be blessed.
I have a 2003 nissan sentra spec-v it was working fine, i parked it, went to crank it a lil while later an it wouldnt start. ivechecked all the basics, starter, fuses and nothing. its almost like the...
MIGHT BE A RELAY ! LOCATED UNDER HOOD, YOU SHOULD SEE RELAY BOX NEXT TO BATTERY. MAKE SURE BATTERY TERMINALS ARE CLEANED, PUT SOME VASOLINE ON TERMINALS, RECONNECT, TIGHTEN. CHECK ALL GROUND WIRES. ARELAY BOX MAY ALSO BE LOCATED NEXT TO POWER STEERING . COULD HAVE A FAULTY SOLONOID@ STARTER, IGNITION SWITCH COULD ALSO BE FAULTY, ITS NEVER EASY TO PINPOINT ELECTRICAL PROBLEMS, PROCESS OF ALIMINATION, CHECK ALL STARTING CIRCUIT SYSTEMS, IS YOUR SHIFT LEVER ALL THE WAY IN PARK ? DOES ENGINE CRANK ? OR DEAD, NO POWER ? ARE YOU GETTING SPARK ? HOW ABOUT FUEL ? DID YOU REPLACE BOTH THE AIR &FUEL FILTERS ? THE STARTER / SOLONOID IS WHAT CRANKS THE ENGINE, I THINK YOUR PROBLEM IS THERE ! REPLACE RELAY TO STARTING SYSTEM, ARE YOUR SPARK PLUG WIRES NEW ! THEY WILL SHORT OUT ANY SPARK IF OLD, DIRTY, I SUGGEST A TUNEUP, NEW FILTERS, AND REPLACE STARTER/SOLONOID !!!!!!
Replaced starter, alternater and battery car still drains battery. whats wrong?
First you can not test an alternator by disconnecting the battery cable. That is what we did back when cars had generators. Today you can fry the computer and alternator running the engine with the battery cable off.
Meanwhile, I would look for a fuseable link or main fuse problem. The alternator circuit may not be connected to the fuse box and battery.
1helpful
2answers
I ve vchanged the battery and alternator on my 94 nissan sentra and the system still wont charge what is the cause
My wife and I have owned three 1994 Sentra cars. One of them went through batteries and alternators like crazy. Last time the 1-year old battery died, I replaced it and went straight to an auto electric shop. The technician found the alternator was putting out about 77 amps the entire time the engine was running (factory alternators are rated for 80 amps, but only when charging nearly-dead batteries). He also found that the harness running to the alternator was hot enough to scald you if you touched it. Miraculously, I found a factory NOS harness on eBay and bought it. Easy to put in, and the car went from a maximum charging voltage of about 13.1 volts, to a MCV of up to 14.1! Haven't replaced a battery or alternator on it since. Hope this helps someone...
Or the battery cables ! Do you know how to use a voltmeter ?
Starter Voltage Drop
Do you know how to do basic automotive electrical testing ?
How to voltage drop test starter motor circuit
Electric Testing Techniques You Need to Know Here is a place to view wiring diagrams ! http://www.bbbind.com/free_tsb.html
88 rx-7 convertible doesn't click or start, new battery and alternator installed 2 months ago ... does the starter/ solenoid need replaced?
try tapping on the starter housing while somebody is in the car. have them try to start the car while tapping on it if it starts replace the starter. who may have a dead spot in the whindings. good luck steve
I have a 94 saturn sl a month ago my car died in an intersection i tryed to jump start it with jumper cables but when it started smoke was coming out of the engine back around the engine i ripped the...
It is possible that you got a defective alternator, but it sounds like you have another problem. Of course, you should check that you have +12V on the field connection of the alternator as well as the battery terminal. I think a more likely explanation is that you have a broken connection or a blown fuse in the engine fuse block. If all of the electrical systems in your car are dead, that is a good sign that the connection between the battery and the fuse block is broken. If you have no power on the power (battery) terminal of the alternator and you have power in the fuse block, then check the fusible link (maxifuse).
Get back to me if you do not find the problem, and I will attempt to help you further.
2001 Nissan Fronteir Crew Cab -- Ignition/electrical issue
it sounds like you have a braker going bad and it just went out the rest of the way...so if you can find the cicret braker that went out and replace it the truck should work fine....or it could be a relay that went out....try this and let me know...good luck..
Electrical. Now. Mon. 7/28/08 9:43 PM
take to a alternator starter rebuild shop. most likely a bad ground or discharged battery
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
