WHEN U FLUSH DOESNT GO DOWN ALL THE WAY THEN TAKES FOREVER TO FEEL BACK UP ITS THE K-4620 MODEL YR.2002
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
SOURCE: Toilet isn't siphoning fast enough. The water
take the uper cover fo the toilet. check for the chain, that chain goes to the balon with air that usualy goes up when water is filling in and stop the water.
so, check for that chain to be long enough (it can be regulated ussually). the problem relies that id the chain is too short the reservoir or tank of water cannot fill up to a 100% to siphoning fast enough.
SOURCE: Elijer Diplomat toilet flushes perfectly,
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
its not in the bowl it self it is the tank im refering to u can see where the water line is on it but its about 2 inches below that and ive checked the lines already there on all the way the bowl fills up fine its the tank that doesnt have enough water i thionk and we have used a snake on all the lines already
The problem that your having is in the flush valve, most can be adjusted, if it is the old skool floating ball valve it can be adjusted by screwing or turning the ball arm in or out from the main body of the toilet valve. If it is the newer gen valve they have notches in the float valve body that can be adjusted. You want to adjust the water level according to the water line in the tank. If anything has been changed tank or bowl? You have to set new water levels to the rating on the bowl. Hope this helps :)
