Medion SK-7225(M) wireless mouse problem. Left/Right buttons and wheel work fine. Mouse won't move the pointer. I've changed the batteries I've recalibrated the transmitter to the receiver I've tried different surfaces and checked for dirt etc blocking the light under the mouse. I've changed USB ports and even tried it on another PC. It was working and got slower and slower and then stopped moving. That's when I changed thebatteries. It it broken or is there a reset I can do?
yooperbud
  • 8637 Answers
SOURCE: MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 28, 2009
leecom72
  • 4806 Answers
SOURCE: wireless mouse wont connect.
Hi there.
Some wireless mice seem to go into some kind of sleep mode, in other words if you leave them for an amount of time they disconnect, the way to reconnect is to right click while moving the mouse.
Also check to make sure that the batteries in the mouse are seated properly.
Good luck
Posted on Jun 01, 2009
  • 72 Answers
SOURCE: logitech v220 cordless mouse - worked fine for 6
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Posted on Jun 17, 2009
iservice
  • 318 Answers
SOURCE: Cannon laser fax 1060 P "check paper size"
Hi Margaret
Ok,the problem normaly with this model is in the feeding of the paper.For some or other reason the paper is moving to slow threw the machine and then the machine detect it as a longer size paper.
  • Clean the rollers that pick the paper up and clean also the sepatation rubbers under neath the paper pick up rollers.This rubbers is called the separation pads.
  • To clean this rollers,remove the cartridge and you will see the feed roller at the back.
I think what happened with the move the machine might collected dust and now the rollers are slipping.
Thanks for you support
Posted on Dec 30, 2009
SOURCE: We have the Brother Intellifax
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Posted on Mar 07, 2011
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
How to make a optical mouse work better?
Your mouse is an important part of your computer system, and when that mouse has problems it is important to get them resolved as quickly as possible.
There are a number of things that can cause a mouse pointer to behave erratically, and it is important to work through each of those possible causes one by one.
Change the batteries if you are using a wireless mouse.
The batteries in a wireless mouse will generally last a long time, especially if you use rechargeable batteries.
But once the battery power begins to decline, the batteries will lose power very rapidly.
If you are using a wireless mouse and the cursor begins to stutter and jump, chances are that changing the batteries will resolve the issue.
Move the wireless transmitter to another USB port.
Problems with the wireless transmitter can cause the mouse pointer to stutter and jump. Moving the transmitter to another port will often resolve this issue.
Right-click on the "My Computer" icon on your computer's desktop, and choose "Properties" from the menu.
Click on the "Hardware" tab, and click the "Device Manager" button.
Navigate to the mouse entry in the list of hardware devices, right-click and choose "Update Driver" from the menu.
Allow your operating system to search for and install the most recent driver for your model mouse.
Clean the mouse surface thoroughly if you are not using a mouse pad.
If you are using a mouse pad, shake any dust or dirt off of it to make sure the surface is perfectly smooth.
Any imperfections in the surface could cause the mouse pointer to behave erratically.
To clean the mouse surface, hold a clean cloth over the opening of a bottle of isopropyl alcohol and soak the cloth.
Then, go over the entire surface with the alcohol-soaked cloth and allow the surface to dry before attempting to use the mouse again.
Click on the "Start" button, and choose "Control Panel" from the menu.
Double-click the "Mouse" icon, and click the "Mouse Pointer" tab.
Adjust the speed of the mouse.
If the mouse speed is set too fast, it can cause the mouse pointer to stutter or hiccup.
It may take a few tries to get the speed just right, so just move the slider and test each new setting
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Hope this helps
Nov 04, 2012 | Computers & Internet
My mouse is plugged in, but is not moving?
There can only be 2 ways. Either receiver button first and then one under mouse or visa versa.
Mar 08, 2010 | HP Wireless Optical Mouse
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
Medion Media PC Model 8828 uses wireless keyboard and mouse,(Liteon SK-7225). The keyboard has failed. Any tricks please? Alternatively, where could I but a direct replacement? Many thanks indeed. ...
The wireless keyboards & mice work on batteries, try replacing the batteries first, if that doesn't work you may try with an USB(or PS2) replacement keyboard/mouse.
Dec 17, 2008 | Computers & Internet
Logitech wireless optical mouse problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Aug 03, 2008 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
Cant get Pointer to move
First try
Then if that doesn't work try
Feb 19, 2008 | Dynex Wireless Optical Mouse DX-WOM100
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
Feb 16, 2008 | BenQ M310 Wireless Mini Optical Mouse
1,976 people viewed this question
jasbo
jasbo
