Question about Zanussi WJS1265W Front Load Washer/Dryer
Machine will not start.
Had a look at my frineds WJS1265W. The control panel lights up ok and seems to work correctly in every way until you press the start button and then nothing happens? I think the door latch is ok because the light is on and it does not allow you to open it. Also tested it is getting cold water out of the single feed. Everything seems normal except this slight drawback of not starting. The start light just keeps flashing as if it is in pause mode (even though it is not). Any ideas would be much appreciated. (I have tried shaking sense into it). Many Thanks, Mark
Hi I am not an expert but, have you looked to see if the pressure swithch is blocked?
Posted on Jun 10, 2007
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
Samsung j1455av front loader washing machine lcd control panel frozen
when you disconnect from power you should wait about 5 minutes prior to reconnecting. Also check the panel to be sure you didn't place it into a "lock" mode. This can be corrected simply pressing the correct selection(s) to "unlock" the control panel.
Make sure the dispenser drawer is fully closed as some units prevent operation until properly sealed to prevent water leakage.
Nov 22, 2017 | Samsung Washing Machines
Xerox Phaser 6180 MFP-D password
The default password is "00000" If this password does not work you can follow the following to reset it:
  1. Power OFF the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  2. Press and hold the [OK] button on the Control Panel.
  3. Continue to hold the [OK] button and power ON the machine. Keep the [OK] button held down until the Ready screen is displayed. The password is now reset to the default Control Panel password, which is 00000.
    NOTE: There will be no confirmation message during or after the machine's power on sequence. However, if the procedure was performed correctly, the password has been reset.
Mar 09, 2011 | Xerox 6180MFP/D Printer
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Jul 06, 2010 | Xerox Phaser 6130 Laser Printer
Lights on Washer Machine flash but Washer doesn't work
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 31, 2009 | Kenmore Washing Machines
Zanussi fj1254w washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 04, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Dec 01, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
The machine doesn't work
Is your load within capacity. See that it is. Press and hold 'spin' & 'dry' for 5 or 6 seconds to unlock controls. Try the machine on a normal cycle once, see if it works.
Apr 14, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Power but nothing happens
Check your washer's plug. Set the wash programme & then press 'start'.
Feb 10, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Machine won't start
My friend got somebody in to fix it in the end. It actually did turn out to be a problem with the door switch. I don't think it was able to lock it's self properly even though the light was on. (Don't know the exact details though). Think they guy just played with the lock to sort it out rather than getting a new part. I noticed when I played with it that if you got the door open, pulled out the plug and switched it back on again it would make a clicking noise for a while as if it was trying to shut it's self if this is any help? Mark.
Oct 21, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS1265W Front Load Washer/Dryer Logo
227 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
