Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Briggs engine/ genreator
Started fine first pull generator sat for a long time. generator does not work repaired generator part then tested by pulling on engine ran fine generater worked fine also. set over night and it wont start. replace old gas with new gas and still won't start? what could it be?
    Sergeant:
  • 359 Answers
Change spark plug and add small amount of starting fluid to breather pull with all settings in proper place if it is going to start it will or you have other problems
Posted on Dec 17, 2008
My electricity provider is not reliable. I own 3 of your towers to heat individual rooms. I have settled on a generator to have when I lose power again. I want to run one of your towers, a light and a...
Each one of your heaters draws 1500 watts on HIGH & 900 watts on LOW. Obviously, your generator can not operate all three on HIGH. On low, all three would require 2700 watts of your generators power. Which leaves very little to operate any other electrical appliances in your home. Becasue these are electric ceramic heaters, there is no surge to them, when you turn tum ON. The wattage listed above, is continual wattage, when they are in use. There has to be an electrical motor involved to have start up surge (i.e Refrigerator, freezer, etc)
So, just operating what you described, will not use up all of your generator's power. You should have just under 1500 watts left over. Of course, if you used a battery operated radio, you could gain 25 additional watts of power.
I hope this helped you and thanks for choosing FixYa.
Sep 23, 2011 | Lasko 751320 Ceramic Heater
I have a PROCOM model ML300TBA, two years old. Here is my problem: Pilot lights fine. Burner lights fine. When I go back the next morning, often times it is out. Burner and pilot are out. It will...
You could try cleaning up the thermocouple with steel wool. Some manufacturers call this a flame generator as well. Any how make sure it is clean and positioned in the top center of the pilot light for best signal. This is only speculation as these are common problems that will arise on heaters in general. This also turns the gas to the burners and pilot light so thats why to start here first. Hope this helps you out.
Dec 23, 2010 | Procom ML300TBA Heater
Model no. TCH048AKD1 Serial No. E044245775 My Tempstar SmartComfort 2000 heat pump will not initiate the defrost cycle. I had a hole develop in a refrigerant line at the condensor unit outside after some...
You can start with a heat gun or good hair dryer and defrost. Upon doing this you need to locate the defrosting element and this is where your problem will more than likely be. You can use a volt ohm meter and check for resistance or open connection. Some times even a blown element will show continuity it will just be lower than normal. Just an educated guess and strong feeling this is the culprit. I certainly hope you did not toss out the defrost control board because now you have a spare. Take your time in pulling out the old element and secure the new one properly, vibration is not kind to elements.
Dec 21, 2010 | Heating & Cooling
Ruud Silhouette II Gas Furnace, purges, lights burners and burns until the blower starts and then burner stops and does not really blow very warm air. Once blower shuts off, it starts the process all over...
Flame sensor needs to be cleaned. turn off the furnace power switch or breaker. pull the flame sensor located in the burner runner section of the furnace. It will be easy to locate because it has 1 wire running to it. pull the screw being very careful not to harm anything else. get the sensor out. inspect it for cleanliness. clean the sensor with light grade sand paper gently. re-install the sensor plug the wire back on. restart your furnace and this should fix the problem.
CookHVACR
Nov 19, 2010 | Heating & Cooling
Not firing
It should be at 750 mv or a bit less if in the system under load, test it out ot system, make sure flame is at the tip of the pilot generator, as the temprerature differentail across its body is what creates the 3/4 volt or 750 mv. easier to simply buy one, test the valve using a AA battery with a wire taped on each end, simulate a pilot generator by attaching the wires where the generators wires went, if it works its ok, and generator is bad
May 29, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Other probable repairs needed when replacing radiator
Sorry to say, with no coolant and no oil It sounds like the engine will need to be replaced. Not a cheap repair,
Oct 15, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
I have the exact same problem
I've had the problem twice. The company told me 500mv on the pilot generator was too low. 3 years ago I replaced the pilot generator and that seemed to fix it. This year same thing, 500mv on the pilot generator, I replaced again and this time didn't fix it and was still 500mv. After poking into everything, here's what I conclude:
- 500mv on the pilot generator is fine, maybe even less.
- you can check the valve and the amount of current the pilot generator provides by clipping a wire from the white to the black on the valve. If this forces the burner on your pilot gen is strong enough and the valve works. Be careful running it this way though, because it bypasses all the safety devices.
- Then check the safety switches and wires. I used an ohmmeter and started working my way from the valve through the fusible link, pressure switch, etc. With that method I found high resistance in a wire from the fusible link when I jiggled the wire. I bypassed just the link, and it's working fine. I've also gone through several pressure switches over the years and a control module as well.
- Everything fails in this heater. It's just a tough environment. the wires and connectors corrode. I live in the northeast, and now in the winter I take out the burner, control module, and thermostat/switch module and wrap a tarp over it. I guess next year I'll pull out the fusible link too, or maybe just solder the connections.
Jun 03, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Furnace runs on utility power but not on back up generator power
I had the same problem with a GH8 Goodman. In the instructions for the furnace are the sentences, "1.Measure resistance between the neutral (white) connection and one of the burners. 2. Resistance should measure 10 ohms or less." Mine was .2 ohms with grid power. It was in the Meg/ohms when on the generator. I made a special extension cord to open the ground at the female end of the cord. Then I connected the neutral (white) wire in side the furnace directly to the ground connection inside the furnace and it worked. Needless to say I was very happy. I do not recommend doing this yourself. This is just my way to stay warm this winter when the power goes out. JohnS
Dec 11, 2008 | Goodman GMS90703BXA Heater
Millivolt Generator burnout
I would check the pilot orfice to make sure you have enough of a flame to heat up the generator. You can buy a orfice drill bit and drill it out one size. The pilot should hit the generator toward the center. You should be able to buy a new orfice for the pilot assembly from the place you bought your heater.
Apr 10, 2008 | Cozy Enclosed Front Console Heater 20,000...
Heating & Cooling Logo
62 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
