Nokia 1100 Cellular Phone
Problem for Nokia 1100
Charging
By noby on Oct 04, 2006
When i connect charger to my phone then my phone shows not charging no screen
Comments:
Oct 04, 2006
- tell me solution
Same Problem
Mar 16, 2009
-   my phone has done the same thing 2 times before and now its doing it again for a third time what i did the other times to let it charge is get a new charge and that worked for about a month or two but than the problem returns -   roxassorarik
Aug 18, 2008
-   When i connect charger to my phone then my phone shows not charging no screen-   jm_dhel64
May 18, 2008
-   My Motorola razr v3 phone will not charge. Does anyone have a solution?-   Richard 111
Apr 27, 2008
-   Yes, mine does this too! The flat charger plug snaps into the phone, but wobbles around, and doesn't always connect to charge. I've tried looping a rubberband around the charger plug and the phone, this worked for a while,but now the connection is easily lost. The phone is perfect in all other respects, i really don't want to replace it. Can I get replacement parts somewhere, and replace the flat plug socket in the phoen? -   sawguy
Mar 18, 2008
-   it wonk wort-   Guest
Best Solution
posted on Nov 02, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try to charge in another socket or
try with another charger
try with your friends battery
if all these doesnt work it should be either battery or circuit problem
Solution #2
posted on Oct 15, 2006
Helpful)
test
Rank: Apprentice
Rating: 84%, 19 votes
Ask your friends for another charger and try it.
If it?s not the charger, take the battery out and put it in the freeze for a few hours if it works a bit you should buy a new battery.
If it?s not the charger or the battery you should fix it in a repair shop or buy a new one.
Good Luck
Was this helpful?
Yes
No
Solution #3
posted on Jan 11, 2008
Helpful)
rajuetw
Rank: Apprentice
Rating: 84%, 3 votes
not charging
Was this helpful?
Yes
No
Solution #4
posted on Jul 02, 2007
Somewhat Helpful)
laba
Rank: Apprentice
Rating: 70%, 3 votes
change the charging prt or the charging ic
Was this helpful?
Yes
No
Solution #5
posted on Jul 25, 2007
Somewhat Helpful)
sadia
Rank: Apprentice
Rating: 63%, 31 votes
CLEAN THE DUST OF UR CHARGING BASE THEN SEE UR CHARGING IC....GOODLUCK
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #6
posted on Feb 11, 2009
Very Helpful)
nadirkamran
Rank: Apprentice
Rating: 100%, 1 votes
my nokia 1100 set is problam not charging plz. tell me solution
Was this helpful?
Yes
No
Popular Solutions for Nokia 1100 Cellular Phone
Questions and Unsolved Problems for Nokia 1100 Cellular Phone
Do you recommend Nokia 1100?
Answer
Answer
how to put my phone book contacts in my mercedes on bluetooth from a nokia 6021
Answer
I need help activating me and my brothers incorparation
Answer
how long will the alarm sound before turning itself off?
Answer
What Is The Master unlock Security Code Samsung SGH-C140 phon
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 11, 2008
s the problem is same
Comment by jms7244, posted on Jan 21, 2008
when i plug in my phone to charge, the connection seems loose. if i play with the cord just right it will start to charge, as long as i hold it. if i move, it breaks connection. is there a problem with my phone?
Comment by chickadeedee, posted on Nov 29, 2007
When I plug my phone in to charge, I am no longer getting the charging icon. There is a red light at the plug spot but no charging icon. Is my phone charging? Why is it doing this?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nokia 1100 Cellular Phone:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 563
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
