My vokera linea 7 boiler is loosing water through over flow pipe while heating up to temperature
  • 4 Answers
The pipe you call over flow. This would be the P/R valve and is set to relieve pressure in system. The first thing that needs to be checked - the expansion tank two types of tanks one would be what is know as a extrol tank, Most likey just hanging off pipe, it has air pressure on one side of rubber dia. and boiler water on other. The 2nd type is just a tank at ceiling height (most of the time). You would see a hose bib off the one end. Tank holds some water but must have air for boiler water to push into as it is heated. If you have the first tank it should be replaced. The 2nd type needs to be drained of all water. Shut off feed line to tank hook up short hose and drain into a bucket. if water stops you must break the vacuum raise hose above tank air should go into tank. repete draining till all water is out of tank. Some tanks have a way to open a valve to let air in as you drain if so use it. When all water is out of tank valve off everything (no air should leave tank) Open back up to system now you should have aplace for the water to expained to.
Posted on Nov 06, 2008
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Hi All, I have a Vokera Linea 735 boiler, 6 years old. when the heating is on, water is dripping out of the over flow to out-side.This results in the boiler losing pressure and having to be topped up...
Kind of need clarification on a couple things. First, what is the PSI operating pressure. Now, onto more questions. You say that when the boiler is operation, it has water coming out of the overflow correct? Then you say that a couple times a day you have to "top it out". Water coming out of the overflow means that either there is to much water in the vessel and it is leaking out when it gets hot due to expansion, or you have a leaking or faulty inlet water valve or sensor allowing cold water to come into they vessel, making it leak out the overflow, thereby reducing the capacity of your heating. You say you have to "top off" the system. How much are you adding and how are you adding it? A pressure vessel normally doesn't have a place to open up and add water because of the nature of the beast. How are you adding water?
Jan 14, 2018 | Heating & Cooling
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
I have a VOKERA 24 boiler the Linea range which was working fine until i notes the pressure was a little under 1.5 Barr. I topped it up the pressure with the filling loop every thing was fine. The next day...
Water logged expansion tank ( ruptured diaphram in tank) or wrong size tank. This caused the excessive pressure in the system causing the relief valve to open. Also, air in the system causing flow to stop, Both conditions will cause boiler go out on safety.
Sep 13, 2009 | Water Heaters
No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Apr 21, 2009 | Heating & Cooling
I have a vokera linea 7 boiler and i get a 01 error code
01 is ignition failure . flame sensor or blocked pilot
Jan 18, 2018 | Heating & Cooling
Vokera linea combiboiler error code CO
It's got nothing to do with carbon monoxide. CO means the boiler is in combustion test mode, that's all (and in this case -- long since fixed, I imagine, but other people will no doubt find this page in the future -- failing). Vokera could probably have made this clearer, but hey.
Dec 23, 2008 | Water Heaters
Vokera Linea 28 combi boiler
sounds like you have an earth leak or defective pump winding
Nov 04, 2008 | Water Heaters
Heating & Cooling Logo
252 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
