Question about Acer TravelMate 332T PC Notebook
Scematic for travelmate 332T LAPTOP
NO DISPLAY ONLY POWER LED IS ON.
Laptop black out
When the following situations, you need to replace the LCD inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More:http://www.lcdinverter.info/acer-travelmate-8001-lcd-inverter-p-2046.html
Aug 08, 2013 | Acer Computers & Internet
Acer travelmate c110ti will not charge
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 11, 2012 | Acer TravelMate C110Ti Laptop Charger...
Hi I have a problem with my acer travelmate 5730. My laptop is always in plugged coz i use it,but lately when i move the laptop the sound of the dc connection is bipping all the time and i have to play...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 24, 2011 | Acer TravelMate 5730-6204 Notebook
How to change cmos battery inside Acer Travelmate 332T
hi shanur, i am happy to assist you,before reading my text its more better for you to see this video on the back of laptop you can find some screw remove it so that maximum part of laptop sheat wil be open in that you can able to find out cmos batter more ever in al laptop i wil be taped, romove the tape and take cmos batter and put new one. good luck
Dec 30, 2010 | Computers & Internet
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
Acer travelmate 2350 wont boot or display
I have seen this on several ACER Laptops. It is always the Motherboard. Contact Acer repairs and order a new motherboard. IT will likely be about $200ish dollars. Then follow one of the guides on the web for taking your laptop apart and replace the board.
Feb 15, 2009 | Acer Computers & Internet
Battery status LED blinkings amber
Try removing the power cable and battery, while these are removed press and hold the power button on the laptop for 30 seconds. this is called a hard reset, what it does is drains any residual power in the laptop. if this does not work, that means there is an issue with the motherboard. to have it sent in would cost about $398, give or take.
Jan 25, 2009 | Acer TravelMate 3260-4874 Notebook
Startup problem
  1. do any of the fans come on when you hit the power button?
May 15, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Acer TravelMate 332T PC Notebook Logo
117 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
