Question about Nokia 6010
#1 button on nokia 6010 wil not respond to touch
Could I have done anything with the settings on my 6010 to prevent the #1 button from operating as it no longer works? I cannot try returning to "Factory Default" as it was never changed from the factory set "12345." Hope you can help.
Trevor
Altho there was no visual evidence to the effect that dirt or liquid was present (or ever present) the problem nonetheless was solved by removing the keypad & blowing compressed air ( available from Radio Shack) in, under and around the buttons on the pad & similarly, the circuit board area that the pad sits on. There are a few access holes that allow you to blow air between the plastic cover plate situated over the circuit board. There are two screws holding that plate in place which I would have preferred to remove but the screws are very tiny & also have unique heads requiring a special tool which of course I didn't have. All the same, the pad worked fine on assembly even though I really have no idea of the real root cause of the problem. It worked for me, regards TREVWEN.
Posted on Nov 05, 2008
My nokia 5230 touch is not working,if I press the screen it doesnt respond
It could be the Digitizer malfunction.You can order a Digitizer from Ebay for around 4-5$ with tools.So easy to install even..12_19_2012_5_52_19_am.jpg
Dec 19, 2012 | Nokia 5230 Cell Phone
Nokia 6010 wont ring.
MY dear Your Phone Ringer Default So Please change Ringer
And Ringing Sound Problem will solved
Oct 21, 2012 | Nokia 6010
My phone powers up fine but my touch screen will not respond nor wil my buttons on the bottom. I tried a hard reset but didn't help. Had been working great. Any suggestions?
If your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Feb 20, 2011 | HTC Aria Cell Phone
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
How to unlock nokia 6010
You can get the unlock code and instructions for this nokia 6010 phone from the site unlockfree
Mar 25, 2009 | Nokia 6010
I have a nokia 6010 phone provider is t-mobile need to unlock it no any codes to try
Friend you can get the unlocking code from http://www.unlock-free.com/ .It provides the free unlocking service for your mobile..By using this you can unlock your mobile easily..
Jan 19, 2009 | Nokia 6010
How do I get the sim card out of a 3100 nokia
1.remove the back panel
2.remove battery
3.remove sim lock
by this you can remove your sim out from your phone.
*but switch off your phone before removing your battery.
Dec 15, 2008 | Nokia 6010
Operation panel buttons not responding
That control board is shot or perhaps the connection to the main board is at fault. Shame but repairing those cameras is very labor intensive and hard to work on. And the parts are not cheap either. I am crazy about my SX 50 but if anything like that happened to me I would just go to ebay and get another one inexpensively. Many repairs on cameras are simply not cost effective.
Sep 09, 2017 | Canon PowerShot S410 / IXUS 430 Digital...
Nokia 6010 Logo
50 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
