Question about HP DeskJet 940c InkJet Printer
Noise then paper jam then printer head stops abruptly and does not work at all
See above
  • Eagle880 Nov 04, 2008
    Thanks I will try it!
  • HP Master
  • 4,338 Answers
Clear the paper jam. Then with a cotton pad and some alcohol, clean all the rollers that you see. If you can get to the rear of the printer, make sure that there isn't any paper residue back there, and also clean the rollers in the back. There is a platen (rod that the print head slides on) clean that too.
Then carefully clean the strip in front of the print head.
Also, never move the print head while the power is on, it will cause the unit to get off it's alignment.
Let me know what results.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 04, 2008
  • JDTec
    JDTec Nov 04, 2008
    If this helps or solves the issue, please rate it. If not let me know.
    Thanks, Joe
How to fix dot matrix printer Printer paper jam?
If you wish to get some details about printers an copiers error codes and repair ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
May 21, 2016 | Matrix Office Equipment & Supplies
Ip90 printer makes a vibrating buzzing noise upon start up
something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
Dec 26, 2013 | Canon PIXMA iP90 Mobile Printer
I had to clear a paper jam in my Artisan 800 printer. i followed the instructions and cleared the paper, but when i turned the printer on the the screen continued to flash and indicate error. the paper has...
This problem is usually caused by the CR Scale forced out of it's **** by a paper jam. The CR scale is a 1/4" wide strip of grey plastic band that is visible when you open the printer. It is right above the serial number. Slide the head carrier to the left and look behind the head carrier. You will see a small U-shaped plastic piece. Make sure the CR scale is within the **** or u shape. Be very careful not to damage the CR scale as you slip it back it. When this scale is flipped out of the ****, the printer head slams into the right side of the printer on start up (twice) and produces the fatal error message, with the paper jam note.
Mar 24, 2010 | Epson Artisan 800 All-In-One InkJet...
My epson cx3200 says paper jam, I dont see any paper jamed, when i press the button to say ive cleared it,it then runs a sheet of paper through it and says paper jam again, surely if there was a paper jam...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Same problem - Paper LED light is flashing, but no paper jam
try on pressing start buttom for 1 min to reset the machine.
it should be working fine after that.
Jun 15, 2009 | Brother HL-2040 Laser Printer
Mac leopard -epson tx400 - printer grabs paper - printer very noisy, desk shakes with vibration - now the print on paper is faded help!!
Hello, sorry to hear you are having trouble,
So, are we to understand that your printer did not shake with vibrations and make a lot of noise before ?
Most of these ink jet printers have heads that travel very quickly and abruptly from side to side causing shaking and vibrations, especially if it is on a light weight desk or table, sometimes to the point of almost throwing itself right off the table. This is a normal state for the printer to be in.
Then, you say the paper is printed on, it goes right through to the end, no paper jam, but the colors are faded...
How often do you print on this printer ? Sometimes, the Epson print head dry up and only small amounts of ink get through even though the system indicates that the ink is full...
You can certainly perform a head cleaning operation, I recommend doing it several (3) times to be sure, unfortunately, it's a terrible wast of ink.
Finally, have you replace the ink cartridges? If you get a faded output with new cartridges, you may have inadvertently activated the ink saving or draft mode, go through you page set-up or printer option thoroughly.
I'm pretty sure something here will get you out of this mess.
Mar 27, 2009 | Apple iMac 17" Desktop
Printer says it has a paper jam even after it has been cleared
The screeching sound is caused when the print head reaches the end of its travel and hits the paper jam which you cannot see using the suggested jam-clearing steps. So
1. unplug the printer
2. lift the cover so the blue support on the left holds the cover up
3. plug in the printer, watch the printer head move
4. after it stops, gently move the printer head toward the middle and look at the far ends of travel. you should find the cause(s) of the jam up against the sides of the printer. remove with needle-nose pliers.
5. replace cover, plug in the machine. it will go through a cleaning or 2, but it should be ready to go after that
Nov 23, 2008 | Brother Multi-Function Center MFC-240C...
ERROR EE2 WARNING
one bad toner has jammed or toner drive clutch has fault. open right cover and you can see witch clutch makes noise. or toner drive moter has problem.
Sep 05, 2008 | Brother HL 2700CN Laser Printer
Printer/Paper Jam Brother MFC
41093dd.jpgWell I fixed it!!! Here's what I did. You see this picture of the cover opened? Where the arrow's pointing is the home position of the printer head. Under there I found a scrap piece of paper! Here's exactly what I did. When I got home I decided to plug it in to see if it would work, but it made the same noise and showed the same error message as before. I opened the cover as shown above. This resets it, and it says "close cover". I closed it, and AS it started to go through its routine I OPENED IT again, and I could see the printer head moving back and forth. At this point I used a flashlight to see where the home position of the Head was, and that's where I found the scrap of paper!
I unplugged it for safety and was able to remove the scrap with my fingers.
By your descriptions, referring to the other users, you just might have the same problem.
Oct 20, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP DeskJet 940c InkJet Printer Logo
53 people viewed this question
Ben Johnson
