Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Kenmore Progessive Lead wire "A" brackets broke on swivel
When using powerhead I lost motor power so I took the swivel apart and found 2 small pieces broken off of the swivel part which held the lead wire "A" in place. Without those pieces the power connector has too much free play and loses contact. Is there a particular adhesive I could use on those broken pieces to hold the lead wire in place so the connector will stay in place or any other suggestions?
  • 125 Answers
You could try GOOP adhesive
Posted on Dec 30, 2008
How do I take apart an electrolux model el12a powerhead in order to replace the swivel?
Remove the screws on the bottom of the power head, you will then be able to remove the top cover to gain access to the swivel.
Dec 24, 2014 | Electrolux Vacuums
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Belt broke, can't get bottom off
if it's the one in the picture then pop off the light cover by gently pushing in and prying on both sides . Remove the bulb by pushing and twisting , OK?, now see the 2 screws? take them out. now flip over the powerhead and gently pry at both sides toward the rear wheels.
Ta Daa!
Oct 01, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore canister switch issue
It most likely is the hose pcb. It has the switch on it, and part of it is either just dirty or bad.
May 17, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Miele Vacuum cannister
Most times you have to replace the neck on the powerhead. Sometimes the switch in the handle of the hose will have a bad solder connection. But S300 is not a good model number, also the powerhead has its own number on the bottom, so couldn't look up parts for you.
Feb 21, 2008 | Miele S300 Bagged Canister Vacuum
Electrolux Epic 6500 Powerhead Motor
Call an Aerus Electrolux dealer in your area.
Jan 29, 2008 | Electrolux Epic 6500 Vacuum
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
167 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
