Question about Toshiba Televison & Video
Can not get any TV Channels, but works fine on CD or DVD playback(movies)
TV Broadcast does not work, just fus on any channels!
Playback is fine and picture is great!
  • Lu_swiss Nov 12, 2008
    Thank's for your help! Voltage supply was OK, but I had to resolder the connections in the tuner.
    Everything works fine now!
Hard to pin-point the problem without examing the set; but, it sound like a tuner problem. First thing to do is to check if your tuner is getting the adequate voltage supplies - generally speaking there should be a pin with 33 vdc, one with 12vdc, and one with 5 vdc. If this is not the case, then it is a power supply problem. If your are getting the appropriate voltages, then check for crack solders on the input and outputs of the tuner. I did one yesterday, were I had to open the tuner and resolder the ICs on the PCB.
Posted on Nov 09, 2008
My dvd player doesn't support wmv, avi, dat, mpeg, mp4 or 3gp. What should i do
This DVD player is supposed to support:
Supported Audio Formats Audio CD, MP3
Supported Video Formats DVD
Number of Audio Channels 4 Channels
Included Units In-Dash Player, In-Dash Monitor, Amplifier
Supported Media Types DVD-R, DVD-RW, CD-R, CD-RW
Monitor Size 6.5 inch
Touch Panel With Touch Panel
Just stick with these formats and it should work fine...are you trying to view burned movies or something. From the looks of it, it should play any DVD or CD just fine. Try to steer clear of those formats you listed.
Oct 18, 2010 | Pioneer AVIC-N2 Car DVD Player
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Sony vx 535 will not record dvd from direct tv channels. It shows that it is recording except on playback it is all black.
if your using a cable or satelite box it will work but has to be on the channel and powered on. dont change stations or it will record you changing the stations
Jul 09, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Dvd player only plays some movies
it might be sevral reasons:
1. Check if region code is the same for movies you playing and DVD player
2. If you using video CDs or copyed DVDs, player might be preventing to playback those kind of discs, due to copyright laws or due to different speed settings for DVD player and discks you using (for intsrance you player can playback DVD/CD+R, and you using DVD/CD-R, or mximum allowed playback speed is 16 you using disk recorded at 24, but this is in case you using burned/copied CD/DVDs)
3. Check it lens is durty. For that use CD/DVD lens cleaning disk
($6 in Walmart, if you are in US)
4. Check if movies you are have the same coloring system, i.e NTSC for US
5. Check CD/DVD for scratches, some DVD players can not playback scratched disks
Please kindly let me know if my information was helpfull for you or you need more info
Good Luck
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Broadcast Channels not picked up
Go into the add/delete channels and add them then program the setbagain.
Jul 10, 2008 | Philips 51PW9303 51" Rear Projection...
Wont record or playback picture
Go to the menu. Select "setup". Then "Channel". Let Auto Channel Memory record your channels. I had the same problem and this worked for me.
Jun 21, 2008 | Samsung DVD-V5500 DVD Player/VCR
Audio on DVR recordings on non-digital channels squeals on playback
Try a system reset by unplugging the unit from all power, wait for 5 minutes and retry. This is an unusual problem...accordianman
Oct 13, 2007 | Arris DCT6200 DTV Receiver
No picture on Television
You have provided incomplete information. What do you mean by 'dvd player works'? Do you mean you are able to view the DVD movies on the TV? Or does it mean that there is power and various lights and indicators on the DVD player?If you are unable to see picture - both while viewing DVDs and also Broadcast channels, then there is a major problem with the TV.Get a professional to have a look, then. But if you are able to view DVD movies, but unable to view broadcast channels, then it is a simple problem of input selection. In this case just select the TV/Video or TV/AV button on your remote, if there is such a button. If no, then use the menu and scroll for input, and then select Tuner. First clearly state what your problem is. Only then we can give you better advice.
Aug 23, 2006 | Jensen JHT-350 System
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
