Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Dead Compressor both fans are working but compressor shut down and won't restart.
  • 1,462 Answers
Take cover off compressor electrics and check start device ok and not burnt out. if compressor is warm to touch, indicates faulty compressor. take all electrics off compressor and check for continuity thro windings.
also check for power to compressor - if no power, indicates fault in board
Posted on Nov 04, 2008
Wine cooler does not stay cool
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Nov 23, 2013 | Avanti Refrigerators
Compressor dosen't restart
replace capacitors might be going off on safety.
Jul 21, 2013 | Dometic Rooftop RV Air Conditioner
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
Jan 06, 2018 | Kenmore 73055 Air Conditioner
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
2002northland 36" refridgerator and freezer not
The compressor should turn on after it cools. It shuts down if it overheats to prevent damage/fire. The compressor itself could be bad but more than likely the fan is dead.
Jan 11, 2011 | Northland 36SSS Side by Side Refrigerator
Refer warming / no compressor / no fan
If the fan doesn't work , the compressor overheats and shut off by the overload protection.I would replace the fan which will cost no more than $30.
Sep 19, 2009 | Refrigerators
Dometic RV A/c compressor runs every 10 minutes
Looks like the fan is jammed or a coil has burnt out, resulting in heat which when detected by the thermostat, passes the compressor to star, but since the fan isn't working it manages to drop the temp near the sensor causing the compressor to shut down & restart quickly. Get the fan repaired/replaced at the earliest & don't use the m/c till then....sodeep
May 16, 2009 | Heating & Cooling
Compressor runs, overheats and shuts does not run...
I have had the same problem. Following the advice of someone on these pages I opened the machine up and checked the fan with a meter. On my model (the 404) it has two settings so two leads; one seemed okay, the other was dead. I checked the circuit where the fan connector plugs in and I got that both speed settings were supplying plenty of juice. Apparently the fan motor is dead. A replacement runs $79 at I ordered one; we'll see what happens.
Apr 11, 2009 | Goldstar DH504EL Dehumidifier
Compressor hums and shuts off
This sounds very much like a compressor failure. unplug the refrigerator and check the condenser for cleanliness. After cleaning the condenser and allowing the compressor to cool, plug it back in and listen for the same sounds. If the compressor was overheated it should restart after it cools. If it does not restart the compressor could be seized. Check the compressor warranty against the age of the refrigerator.
May 19, 2008 | Kenmore 72912 / 72914 / 72919 Bottom...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
289 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
