Question about Pioneer DEH-P8600MP CD Player
Need pic of power, speaker harness
Could anyone please provide me with a picture of the power, speaker harness? thanks in advance
    Problem Solver:
  • 18 Answers
Http://cgi.ebay.com/PIONEER-WIRE-HARNESS-DEH-P8400MP-DEH-P8600MP-DEH-P960MP_W0QQitemZ190037675247QQihZ009QQcategoryZ39752QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting ------ copy and paste this. i hope this is what your looking for.
Posted on Oct 04, 2006
  • bobby allen Oct 04, 2006
    sorry just click
SOURCE:
I need a COLOR wiring harness diagram for john deere la130 riding landowner. i do not have manual. need to know if im missing any parts. i need to know where the colored wires go. -red -red & black...
ok i found a picture diagram for what looks like to be your harness but i you need to get the numbers off the wireing harness its self
these can be very helpful in locating the proper diagram and wireing instructions for this harness
now the pictures and color codes is on a picture at bottom of the link i put in here so hope the link helps youll have to zoom the pic
there is two types of harnesses with the four points (meaning ends)
one is for the clutch and one is for back panel behind steering wheel the guages red is always hot red and black striped is key accessorie hot
yellow is usually the on position once key starts to engage blades or clutch
the blacks are grounds
need a good pic of this harness with out hand in way and closer but showing all the end points ive worked on these but i would rather see it better with more pics if possible
Nov 09, 2013 | Cars & Trucks
Some cables are missing after shipment from US to Philippines. Need a picture of all the cabling from Amplifier to Subwoofer and to the speakers, please.
  • The first cord you see at the top is the Bose System Input Cable.
  • The rest are standard speaker wires in different lengths.
  • Then you have the Power corn on the very bottom of the pic.
  • Thank you for using FixYa
Regards, Tony
Jun 20, 2011 | Bose Acoustimass 10 III System
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Jan 08, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Kenwood car radio/cd player Model No KDC-3027
Do you like need the colors codes for the harness like speakers and and all?
Nov 19, 2008 | Kenwood KDC-3027A CD Player
Need to install new radio
This should Help:)
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Oct 25, 2008 | 1991 Honda Accord
Cant send picture from my phone to someone elses
Yes you will need to check with your provider if you have MMS available if not ask them to send you the settings or turn it on for you.
Once you have recieved the settings save them to your phone,turn your phone off then on and send a pic to yourself as this will then activate the settings between your phone and the provider
Nov 02, 2007 | Motorola Mobility RAZR V3
Dead LCD
What kind of LCD are you talking about?
Jun 28, 2007 | iLO V27DMBX Television
Connector Pin Out
Apr 05, 2007 | Kenwood KSC-WA100 Car Subwoofer
Pioneer DEH-P8600MP CD Player Logo
276 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
