Question about Bosch Nexxt WTMC3321US Electric Dryer
My Bosch nexxt electric dryer won't turn on
My bosch dryer has worked well for four years this morning I took a load out and put in a new load an it would not start. The selector still lights up but and the door switch looks fine. I unplugged and replugged in the dryer and still it does not work. any suggestions? did it may be blow a fuse? when I push the button to start I do hear a click like it is trying to start.
  • dwils4230 Dec 27, 2008
    same problem
  • Wh3k2ba1g Feb 28, 2009
    the lint filter light will blink, then go out - the start button keeps blinking and even though we keep pressing the button (it does click) it just won't start
    we've cleaned the filter and the dryer but still won't start
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Posted on May 26, 2009
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Jun 05, 2012 | Bosch Nexxt WTMC 6300 Electric Dryer
Where do I find the reset button on my Bosch Nexxt 500 series dryer? The dryer will run, but no heat is coming out.
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
Mar 01, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
MY BOSCH NEXXT 500 ELECTRIC DRYER IS RUNNING ON 20 MIN AIR DRY BUT WITH NO HEAT. SOMETIMES BY SLOWLY MOVING THE DIAL WILL ALLOW THE HEAT TO RUN FOR A FEW MINUTES. THEN LINT SENSOR GOES ON. HAVE CLEANED...
Did you check this FIXYA LINK below? Appears to have lot's of answers!
Also I WATCHED the YOUTUBE video I recommended and NOTICED his DRIVE BELT is WAY too loose! Methinks THAT is why his dryer has problems!
Be SURE your belt is not to aged because they can STRETCH and then TRIP the "RESET SWITCH" he's talking about. Note the way his PULLEY shakes so violently... AND the action of the belt itself...
20 Most Recent Bosch Nexxt 500 Dryer Questions Answers
Here is another Link!
Bosch Dryer Won Heat 3 min FIX
And yet another!
(DON'T waste your time with the FOUR oval Links to the right! )
Dec 22, 2017 | Bosch Nexxt WTMC 6300 Electric Dryer
My dryer is not getting hot or even warm
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Bosch dryer making rumbling /grinding noises low frequency
you might want check the rollers that tub rides on they are in the front lower part of the dryer, or the belt that turns the tub.
Jun 23, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer
I have a Bosch Nexxt WTMC 3300 electric dryer. The dryer doesn't heat up. This is the second time this has happened over a one year period. The first time it happened, the technician reset the thermal cutoff, but said he saw no reason why it should have tripped. Can you tell me how to reset the thermal cutoff or offer another solution?
Apr 25, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC3321US Electric Dryer Logo
898 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
