Question about Samsung SyncMaster 750S Monitor
Setting I was trying to reset the size on the monitor, but the monitor has locked and cannot be adjusted, it has now shifted to the left and I cannot center it, is ther a combination of buttons to press? no manual was a gift. Thanks
  • Jasmine96 Nov 12, 2008
    Hi! I am having the same problem with my monitor! Adjusted the size and now the entire viewing area is smaller and shifted to the left...help!
Thank you so much for responding so quickly, I actually sent an email to Samsung (after much searching I located information on the monitor ) and they sent the manual in power point. I was able to unlock the screen and reset the size center the screen. If you would like I can send the manual to you so you have it to pass along to any one else.
Posted on Nov 05, 2008
The monitor`s display adjustment panel is showin "CONTROL LOCKED" I cannot change any settings(like brightness,v-size,etc)... wat do i need to do?? plz suggest
Well for Sumsung with a 3% failure rate is unusual, I would try and reset to factory settings if that does not work, They have a pretty good waranty on them seeing they never break down. average is 3yr.
Jul 14, 2010 | SAMTRON 55V 15" CRT Monitor
The screen has shifted to the right so that i cant see the [X]on any windows. Ive already maxed out the left shift but its still stuck to the right.
does the screen appear distorted;does it move as you shift left/right/up/down? IF THIS IS TRUE, YOU PROBABLYHAVE THE RESOLUTION SET WRONG....RIGHT CLICK ANYWHERE ON THE SCREEN;PROPERTIES;SETTINGS; ADJUST SLIDEBAR TO PROPER RESOLUTION FOR YOUR MONITOR
Mar 07, 2010 | AOC 2216Vw 21 inch LCD Monitor
Is there any way to adjust the screen image size? I recently connected a computer to the DVI input, and at 1280x720 there is quite a bit of overscan. Is it possible to reduce the image size?
Change the display settings on the computer desktop, try various sizes.
If using programs like word or firefox change display size with shift/mousewheel. Also change font sizes for best view. Don''t worry about resolution numbers, adjust for good picture.
Mar 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
The text is too tall and not wide enough. How do i adjust the monitor?
If you are using Xp right click on a blank spot on the desk top select properties,in the display properties you will see settings.There is a option to adjust the screen size,move the bar to the left will increase the size.Under vVsta you will right click on a blank spot on your desktop select personalize,select display settings there you can adjust the bar to the left to adjust your display.Remember to apply the changes before you exit.
Good luck
Sep 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Start up screens are off to the left.
There's nothing wrong with the monitor. Monitors remember the settings for different video modes, including horizontal position. The video mode used when the splash screen displays is a size almost every monitor can handle. Then the mode switches to whatever you've set once Windows finishes startup. As long as the display is normal once Windows is running, you really don't need to be concerned.
If you want to correct the problem, you need to put the monitor into the same resolution and use its menu functions to adjust the size and position. Try pressing F8 when the machine boots to get into the Windows startup menu. This will probably also be shifted, so you can adjust the settings while the menu is being displayed.
Apr 16, 2009 | Computers & Internet
SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
Feb 14, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Polaroid monitor picture is shifted to left about an inch
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Dec 21, 2008 | Polaroid Computers & Internet
Control locked
try this option press hold menu en arrow button to adjust setting en fix it for your best display set your resolution on 1024x768 60hz after that disable osd by removing resistor located on crt board loc# r117 tnx and good day.
Apr 04, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor display shifted offscreen
I would be carefull with refresh rates unless you know the maximum and minum rates to apply to your monitor. I solved this problem before for someone and what i recomen is to set your normal desktop to the same resulution as your computer games. That way when you leave your games or reboot it will be the same. See what is happening is when you play your games it is a higher resultion then your normal desktop. And when you log off from it your monitor has to re adjust to the old settings. This will cause a shift. By setting them both the same you will avoid this problem all together.
Sep 20, 2007 | Mag Innovision LT765b 17" Flat Panel LCD...
Samsung SyncMaster 750S Monitor Logo
151 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
