Crackling power switch on NAD 3220PE
Whenever I turn on my NAD 3220PE, there is a crackling sound for about 30 seconds or so and then it subsides and the amp works fine. I took the amp apart to see if I could figure it out and I've located the problem in the power switch. The part is sdu3p tv-3. I turned it on in the dark and saw electric sparks (or maybe they were not sparks, but arcs or something else) on the switch itself. I was wondering if anyone knew how to get a replacement switch or a way of bypassing this problem. (I am not above jerry-rigging, I just want this amp to work) Thanks!
  • PooDog7 Nov 05, 2008
    I will try to get ahold of some CRC and try that first. It may be a few days, but I'll get back to you and let you know how it went and then proceed from there. Thanks! One more thing, am I right in trying to repair this amp? I am currently using a Pioneer SX-205 as a temporary replacement, but it seems to be coloring the sound. Or maybe it's not and the NAD was instead. I think the NAD is better, but just wanted to be sure. Thanks again!
  • 1,512 Answers
Hi, i would try flooding trhe switch with CRC 2-26 for a start. Itr may recover some contact integrity. A jerry rig solution would be to bridge the switch contacts and leave it on all the time(i leave my amps running all the time) or if as in Australia you have a switch on the wall socket use that,
OR purchase a new switch from here. Not sure how you would go through NAD, probably dont have any in stock as a spare these days.
or if that does not work out, I could get one to you through ebay. Used to be quite a common TV switch, but I also remember replacing then in Nad amps, many moons ago ;) I think I still have a one in stock myself, packed away from when I was a NAD service agent:)
regards
robotek
Posted on Nov 05, 2008
  • Graeme Ross
    Graeme Ross Nov 05, 2008
    hehehe you are experiencing just why NAD have such a reputation for building amplifiers. They DO sound better. The SX205 is not a bad amp either, but I have been a NAD man since the early eighties. Fix it if you can. particularly if you like the sound of the amp. It can be hard thing to find that "listening nirvana"
    A FixYa rating is a great reward for my efforts to assist you. Cheers .
    regards
    robotek
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have this amp & believe it still sounds very good. Keep it or sell it on craigslist. It will sell very quickly.
Posted on Apr 02, 2009
Crackling
So if you bought enclosures that are premade AND had the speakers installed, you need to see if there is a cross over network installed in them
Apr 27, 2013 | Car Audio & Video
LGTV 42LCD - LOUD CRACKLING SOUND ON START UP -
Either your main pcb has a defective auido circuit or speakers are bad. Doubt it is the speakers or it would do it all the time.
Mar 20, 2013 | LG 42LC2D 42 in. LCD HDTV
Crackling sound when changing stations on cable box
Whenever the channels are changed, the TV consumes more energy momentarily to load the new graphics. If there are any minute loose contacts in RC jack, cable or sockets, you might get this problem. Same applies to loose contacts in power outlet also. The next chance is leaky/dry capacitors in the TV and might require attention by a qualified service technician.
Aug 21, 2012 | Hisense Televison & Video
Hi, I have a second hand NAD 3240PE amplifier, the right channel has an intermitent crackle but the left channel is fine, Any ideas as to what might be causing this problem?
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Dec 28, 2009 | NAD Audio Players & Recorders
I have a nad 7600 receiver. it is cracking and popping loudly whenever you try to adjust the volume. What could be the problem
There are a couple of possibilities here. The crackling is likely to be a dirty control. Spraying it out with electronics switch cleaner that contains a lubricant should resolve that. The popping usually indicates a build up of DC current between the amp stages. This can happen because of defective coupling caps. That may take a little more detective work. Try cleaning the controls first. If that fails to reolve the entire problem, update this and we'll start looking at circuit components.
Dan
Aug 21, 2009 | NAD Audio Players & Recorders
I have crackling coming out of my speakers
Most cell phone cause problems with electronics and computers. Have them turn the cell off and enter again. Maybee this is the problem.
Jun 21, 2009 | Aiwa AV-D57 Receiver
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
Dec 08, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
592 people viewed this question
 Grubhead
Grubhead
