Question about Sony WEGA KE-37XS910 37 in. HD-Ready Plasma Television
Help! Sony KE-37XS910 Plasma has a green and sometimes red vertical line!
I have had this tv for about two years and it has been working great. However, recently, I noticed an annoying problem. When the TV is on, there is a green vertical line (not solid but rather like dashed) appear on the right edge of the screen. Sometimes, it disappears on its own but most of the time it stays. What's the problem? How do I reset the tv back to original manufacture setting. I appreciate your response.
  • Eddy P Nov 04, 2007
    In addition of the green vertical line on the right edge of the screen, I also have a vertical red semi-line about 4" from the left edge. This is happening after 2 years of use
  • RDJones Jan 02, 2008
    Three colored lines on right and one line on left.In normal mode,it is also white(Normal)on left but black on left.
    Please help.
    Thanks,
    Ron
Nope - figure it was something internal and would cost much to fix...
Posted on Nov 14, 2007
    Champion:
  • 217 Answers
Sounds like the logic board is bad
Posted on Feb 17, 2007
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
6 blinks
trying to locate you to ask you if you found out the problem to your sony ke37xs910 plasma 6 blinks. i have the same tv with the same problem. does your tv set have sound but no picture.
May 05, 2010 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Lines on Sony Plasma HDTV
it can be fixed but in this case i doubt its worth fixing. these problems can be astronomically expensive and personally i would buy a nice new bravia or something similar. please rate
May 11, 2009 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
This TV has a very expensive panel... we are talking $3000 core charge alone! It comes complete with all the lower buffer boards (which from the sound of it, you are having a problem with). Individual boards for this defect are not available on repair parts list I know of. A panel is what you need, PN: 9-885-063-33
Aug 17, 2008 | Sony WEGA KE-37XS910 37 in. HD-Ready...
SONY Plasma Vertical Line
The problem is one of the flat cable connections at the bottom of the panel. Turn set on then heat each connector for about a minute with a hair dryer while watching the display in a mirror. The line will dissappear.This is the faulty connector. Take it out clean with contact spray cleaner put it back very very gently. This will solve the problem. All this is done entirely at your own risk. If you are not sure take it to a shop...Peter ezyer@hotmail.com
Apr 24, 2008 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Sony KE37XS910
MODEL: KE37XS910, KE42XS910
SUBJECT: 9 Blinks of StandBy LED
CAUSE: Change the Switching Regulator part number 1-468-794-12.
Oct 29, 2007 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Sony Plasma Wega KE-37XS920 No VideoSignal
If you still have your receipt for repair...take it back for repair again.
This time, you should have some kind of warranty on the last repair, so you should have to pay minimal (if anything) to get it fixed again.
If it is the logic board, insist that you are given the faulty one....that way you can see that it has been done and you can then dispose of it at your leisure, "knowing" you have not beem conned into paying for services not given.
Hope this helps
Oct 16, 2007 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony WEGA KE-37XS910 37 in. HD-Ready Plasma Television Logo
434 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
