Need wiring help for viewsonic or winfast computer
In the back of com, there are 8 wires,2 of them are singles,and 3 of them are doubles. Need to know how they go on,
  • ellocopoyo77 Mar 08, 2009
    ya, i could use this too.
Wiring diagram
Posted on Nov 04, 2008
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
Motherboard
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
http://www.devhardware.com/c/a/Motherboards/Foxconn-Winfast-NF4SK8AA8EKRS-Motherboard-Review/3/
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
http://www.techsupportforum.com/forums/f15/winfast-mobo-front-panel-connection-558456.html
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
No?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 30, 2013 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
Switch not working
I have an older electric Perfect Chair model and the switch has go out twice.
To fix mine here's what I did. you will need a butterknife, scotch tape, flat screwdriver, allen head wrench to fit screws on inside panel.
1. Scotch or painter tape on the wood around the switch so as not to scratch it.
2. Pop the switch box out of the wooden chair leg by using a butterknife edge (similiar flat tool will work).
3. There are six wires attached to the switch-single orange, double orange, single yellow, double yellow, blue one and a red one. Diagram which
wires go where so can hook back up correctly.
4. Unhook the wires from the switch.
5. Easier to rehook up the wires if remove the panel from the inside of the wooden chair leg. Need the correct size allen head or six sided wrench to remove the the 3 screws on this panel.
6. Open the switch by popping up the button. gently use a small screwdriver to do this.
7. There are 2 small metal slips/pedals at the bottom of the switch. the switch stops working when one or both of these get out of place.
8. Need to replace the metal pedal in correct position.
9.Replace the the button on the switch carefully to avoid disturbing the metal pedals.
10. Hook up the switch wires-see #3 and 5 above. my chair worked after this fix ! let me know if this helps - rhph@sbccglobal.net
Apr 05, 2013 | Human Touch The Electric Zero Gravity...
I need to know the firing order of my 1995 limited jeep grand cherokeemy spark plug wires are missing i have new wires i just don't know the firing order
For the 1995 Jeep Grand Cherokee:
I do not know if you have the 4.0L In-Line (Straight) 6-Cylinder or the 5.2L V8; however I have included bothe below.
For the 4.0L In-Line 6-Cylinder:
Firing Order:
1-5-3-6-2-4
Cylinders:
(back)
|..6..|
|..5..|
|..4..|
|..3..|
|..2..|
|..1..|
(front)
Distributor:
...(back)
....5...3.(+)-screw
1...........6
(+)4...2
...(front)
For the 5.2L V8:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
.......(back)......
|..8..|........|..7..|
|..6..|........|..5..|
|..4..|........|..3..|
|..2..|........|..1..|
.......(front)
Distributor:
.......(back)
.........3
...4.........6
8...............5
...1.........7
.........2
.......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
May 21, 2010 | 1995 Jeep Grand Cherokee
I need firing order specs,pitures,schematics of coil/wire
I do not know if you have the 4.0L OHV V6, 4.0L SOHC V6, or the 5.0L V8; however I have included all of them below.
For the 4.0L V6:
Firing Order:
1-4-2-5-3-6
Cylinders:
..(back)
3...........6
2...........5
1...........4
..(front)
Distributor:
(back)
3...4
2...6
1...5
(front)
For the 4.0L SOHC V6
Firing Order:
1-4-2-5-3-6
Cylinders:
...(back)
3............6
2............5
1............4
...(front)
Distributor:
(back)
1...2...3
5...6...4 (this was double checked)
(front)
For the 5.0L V8:
Cylinders:
.....(back)
4................8
3................7
2................6
1................5
.....(front)
Ignition Coil Connections:
.......(back)
_____...._____
|.4..7.|....|.3..5.|
|.8..2.|....|.6..1.|
.......(front)
Mar 20, 2010 | 1999 Ford Explorer
I need the wiring diagram for a 305 motor in a 1997 chevy truck
For the 305:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
(back of engine)
8............7
6............5
4............3
2............1
(front of engine)
Distributor:
....(back)
.....3.....6
4..............5
8..............7
.....1.....2
.....(front)
Mar 04, 2010 | 1997 Chevrolet K1500
My apologies for the delayed response.
I am going back to answer - unanswered questions. I have only been on this site for the past 4-months. Questions Posted have exploded (+55%) since joining.
I do not know if you still need this information, but I am answering it either way.
I also do not know if you have the 4.9L, 5.0L, 5.8L or 7.5L Engine; however I have included ALL of the them below:
For the 4.9L
Firing Order:
1-5-3-6-2-4
Cylinders:
(back of engine)
.........6
.........5
.........4
.........3
.........2
.........1
(front of engine)
Distributor:
(back)
..........4
(+) 2.........1
..6...............(+)-screw
................5
........3
For the 5.0L AND 7.5L:
Firing Order:
1-5-4-2-6-3-7-8
Cylinders:
(back of engine)
4-----------8
3-----------7
2-----------6
1-----------5
(front of engine)
Distributor:
.......(back)
...(+)-screw
.........5
...4...........1
2................8
...6...........7
.........3
................(+)-screw
.......(front)
For the 5.8L:
Firing Order:
1-3-7-2-6-5-4-8
Cylinders:
(back of engine)
4-----------8
3-----------7
2-----------6
1-----------5
Distributor:
.....(back)
(+).3.....1
7...............8
2...............4
.....6.....5..(+)-screw
.....(front)
Feb 17, 2010 | 1986 Ford Econoline
I need a print out of the spark plug wiring diagram
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway.
I'm not sure if you have the 2000 Dodge 1500 with the 3.9L (6-Cyl), 5.2L (8-Cyl), and 5.9L (8-Cyl) Engine; however I have included.
For the 3.9L (6-Cyl):
Firing Order:
1-6-5-4-3-2
Cylinders:
(back of engine)
6----------5
4----------3
2----------1
(front of engine)
Distributor:
(+).6...5
1...........4
...2....3..(+)-screw
For the 5.2L AND 5.9L:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
(back of engine)
8...........7
6...........5
4...........3
2...........1
(front of engine)
Distributor:
.......(back)
.........3
....4........6..(+)
8...............5
(+)1........7
.........2
Again my apologies...
Let me know if this helped, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Jan 18, 2010 | 2005 Dodge Ram 1500
3 wire white rogers zone valve operated by 2 wire thermostat any one have a wiring diagram?
It is technically possible use a 2-wire thermostat with a 3-wire zone valve, but you need a single pole, double throw relay like a fan control relay with one normally open switch and one normally closed switch. 2-wire thermostats only have one switch that is normally open. 3-wire thermostats have two switches......one switch that is normally open, and one switch that is normally closed. The fan relay lets the 2-wire thermostat simulate a 3-wire thermostat. It's possible, but usually it's easier to just get a 3-wire thermosts.
Sep 06, 2009 | Heating & Cooling
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Computers & Internet Logo
527 people viewed this question
David Payne
David Payne
