Question about Kodak EASYSHARE 5100 All-In-One Printer
Not printing new black and color ink still no print canot finf option to clean print head
  • 40 Answers
The option to clean the printhead is on the Kodak AiO Home Center, when you open it you need to click on the Question Mark (?) and then, under General Links, click on "Maintenance", then a new window pops up and you will see the option to clean the printhead.
Although, most likely it still won't work, so I recomend you to call Kodak AiO Printer support at  1-800-421-6699 to have your printhead replaced.
Posted on Nov 06, 2008
Mg7120 won't print black on paper,but will print pictures with black just fine
It looks like you may have 2 black ink cartridges; one for black-and-white printing, and one for color printing. The larger one may have clogged nozzles. Run a cleaning cycle several times, and see if that solves it.
Other options which would be entirely at your own risk:
1. Dabbing the print nozzle head with warm water on a cotton swab.
2. As above with a mild solution of rubbing alcohol.
3. Soaking the print head overnight.
4. Applying vacuum to the print head.
Feb 11, 2017 | Black Office Equipment & Supplies
Why won't my printer print black ink?
U may want to check the settings, sometimes with a few printers I've owned they give an option of using only color inks in cases where the black ink is out.
Aug 01, 2014 | Lexmark S415 All-in-One Wireless Color...
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
Don't print the black color
Doing reference on your issue. Double check the ink cartridge to make sure that the cartridge is correctly installed. Also be sure that the black ink cartridge used is compatible with the machine.
The next thing to do is a cartridge cleaning as the belief is that the print head is blocked. If you have done a thurough cleaning, the next thing to do is replace the black ink cartridge to be certain the ink cartridge is not faulty.
I have included print head cleaning instructions in case you have not done this cleaning process.
here is some information from the Brother support site:
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may solve the problem.
Cleaning the print head may solve the problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then choose ALL.
When the machine completes cleaning the print head, press Color Start. A Print Quality Check Sheet will print.
Brian
Jan 22, 2011 | Canon MX700 Office All-In-One InkJet...
All colors print only black does not print. New
reset your print option set automatic or color select
Aug 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
Canon ip5000 won't print black
try taking the cartridge out and cleaning it then replace it after that unplug it for a couple minutes and then plug it back in and let me know what happens
Jan 17, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Cannot print in color
need head cleaning , check your option color or black , adjust in maximum color , mostly some printer there many option.
Dec 14, 2007 | Lexmark X5150 All-In-One InkJet Printer
Printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
May 05, 2006 | Epson Stylus CX4600 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
