Question about Braun KSM 2 Electric Blades Grinder
Ksm 2 is new.
My ksm 2 is new. the very first time I put coffee in to be grinded, and pressed button, it ran for about 3 seconds and quit, and now I can't get it to power at all when I press button.
    President:
  • 3,433 Answers
Read previous post.
Posted on Jul 14, 2009
  • Ned C Cook
    Ned C Cook Jul 14, 2009
    read previous post.
How long is it safe to continuous grind
I burned mine out and had to repair it by trying to grind a pound of beans. I say pulse works the best--2-4 seconds each burst. One can grind 5-10 seconds but it heats up inside and in my case, contact melted (metal) from ongoing current to motor via switch. I rigged it but would recommend staying under 10 seconds. pulsing works best in coffee grinders and food processors.
Jan 20, 2013 | Braun KSM 2 Electric Blades Grinder
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
My grinder has been working fine until this morning I did the usual plugged it in and it did not work. could the engine be burnt out. it is my favorite appliance for coffee grinding. please help. I would...
if you ground for a long time...20-30 seconds, you may have burned out the thermal control protection that keeps it from catching fire. It is a guess without more history.
Apr 07, 2011 | Braun KSM 2 Electric Blades Grinder
Greetings: Problem with auto grind Cusinart DGB600 coffeemaker. Properly prepared coffeemaker to brew coffee but noticed time is replaced by - - - . Suspected it was time to replace cleaning filter, which...
sounds like the coffee maker had a power surge. Try setting the time again.
1. Setting the Clock When the coffeemaker is plugged in, 12:00 will appear until you set the time. Entering "Time Set" Mode: To set the time, hold down either the "Hours" or "Minutes" button until the clock begins flashing (about 2 seconds). You are now in the "Time Set" mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or pressed and released lightly to advance one digit at a time. When scrolling, the numbers will advance slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting, release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired. Exiting "Time Set" Mode: The "Time Set" mode can be exited in one of two ways: 1. Press any button besides the "Hours" or "Minutes" button. This will exit the "Time Set" and activate the selected function. 2. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Time Set" mode will be exited. 2. Setting the Program Ti m e : When you press the "Program Set" button, it displays the current program time (default time 12:00 p.m.). Entering "Set Program Time" Mode: Press and hold the "Program Set" button (about 2 seconds) until the green light and LCD display begin to flash. This signals that you have entered the "Set Program Time" mode. The desired time can be set by pressing the "Hours" and "Minutes" buttons to scroll forward through the digits. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The coffeemaker will start to brew at the programmed time. The "Program" mode cannot be entered if the c o ffeemaker is in its "brew" cycle. Exiting "Set Program Time" Mode: "Set Program Time" may be exited in any of three ways: 1. Press the "Program Set" button. This will cause the coffeemaker to revert to its previous state. If it was OFF, it will return to the OFF position. If "Programmed", it will revert to this state, and so on. This is a safety feature. 2. Press any other button (except "Hours" or "Minutes"). "Set Program Time" will be exited and the function of that button will be executed. 3. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Set Program Time" mode will be exited and the programmed setting will be in effect.
Dec 28, 2010 | Cuisinart DGB-600 Coffee Maker
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Just bought a cuisinart grind & brew dgb-550 and can't get the program setting to work. Tried putting in a time and leaving it and tried pushing the program button after entering the time.
Push the program button one more time - the first push allows you to set the time, the second push stores the time you have just entered, and then you have to press it one more time to make the light next to the program button light up tell it to brew at the set time.
Aug 23, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
Jul 13, 2009 | Braun KSM 2 Electric Blades Grinder
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
Braun KSM 2 Electric Blades Grinder Logo
143 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
