Question about Maytag MAH8700A Front Load Washer
MAH8700A Error code 2E What does this mean?
Thanks in advance for any help - I have a 3yr old maytag MAH8700A getting error code 2E - I called maytag parts to get an explaination of that code so I could buy the proper part ... they didn't have that error code in their manual.
please help!
  • Anonymous Mar 25, 2009
    what can be done besides replacement
  • joeigarcia Mar 29, 2009
    I laid the washer down to remove and level the riser and when I stood it up an plugger it in I got error E2. The technical information that came with the washer says
    Display "E2" "Go to membrane pad Check" Check connection of keypad to control board, replace console if necessary.
    The technical information dose not tell you how to check the membrane pad.
The washer is over filling turn off the water off and put in on rinse
Posted on Jun 01, 2012
I've got similar problem. Did you ever get it running? Without buying the $198.00 control board?
Posted on May 26, 2010
According to the trouble shooting manual that came with my Maytag MAH8700A, code 2E refers to "Voltage for motor control bus is under specified limit." It states that the action to be taken is to "replace motor control board."
Posted on Feb 22, 2009
Door won't open
If you're going to trash the machine, then you could use a large pry bar to force the door open from the hinge side - or a Framing hammer, with splayed flat forks. drive the prying instrument into the hinge side of the door with a hammer and pry away!
Hope this helps!
Dec 17, 2013 | Maytag MAH8700A Front Load Washer
Maytag mah650aww diagnostic codes
The code is actually "2E".
The 2E refers to a problem with the motor control board. It has sensed a fatal error. The corrective actions needed in this case is the motor control board to be replaced. Here is the replacement control board.
Oct 18, 2012 | Maytag Neptune MAH5500B Front Load Washer
Error code E3
Dont know the code but what is it doing? Maytag shops all over US you could call them or get on their website
Feb 18, 2011 | Maytag MAH8700A Front Load Washer
I keep getting an error code ... F-20. Please
F20 indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Jun 29, 2010 | Maytag MAH8700A Front Load Washer
What does a 3E error code mean? i have a maytag
Trouble shooting guild for this machine indicates this means Motor Failure. Over current is detected
Feb 08, 2010 | Maytag MAH8700A Front Load Washer
Maytag washer has error code of dc
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#$
Mar 27, 2009 | Maytag MAH8700A Front Load Washer
Maytag mah8700A
ds - means that the door is open while the washer is running sometimes this can be easily fixed by opening the door then closing it and pushing it pretty firm to make sure it latches.
If that doesnt work there very well could be a problem that would need to be fixed by a service repairman you can call Maytag USA Customer Service @ (800)688-9900
hope that helps.
Jan 27, 2008 | Maytag MAH8700A Front Load Washer
Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Jan 23, 2008 | Maytag MAH8700A Front Load Washer
Error code "sr"
Sr is a stuck relay on your main board.Replace your pc board.
Dec 30, 2007 | Maytag MAH8700A Front Load Washer
Maytag MAH8700A Front Load Washer Logo
1,018 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
