Question about Sabrent (USB-UF6) (USBUF6) Serial Adapter
No device recognition!
I installed the USB-UF6 into my Dell 4400 pc, 1.89 mhz, with windows xp home. Winows identified the controller card and the ports, but when I plug in a USB device (thumb drive etc.), there is no recognition in any of the external ports. Windows shows the USB driver to be (5.1.2600.2180) and the fire wire port driver as (5.1.2535.0) Also, the windows version is 2002 with service pack 2. Please respond with a solution. Thanks, Bill
  • Anonymous Jan 11, 2008
    I installed the Sabrent USB-UF6 and the device manager recognizes the card with the error code 10 will not start. system is an acer pc running windows xp.
    Ed
  • 39 Answers
Install the manufacturer's drivers not microsoft.
Posted on Aug 26, 2007
Gateway 310 s won't recognize a cd
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
2. Click to select your computer as the location for the scan.
3. On the Action menu, click Scan for hardware changes.
Windows XP recognizes the new device.
4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2.
Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
2. Expand Universal Serial Bus controllers.
3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
4. Click the Power Management tab.
5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
6. Repeat steps 3 through 6 for each USB Root Hub in the list.
7. On the Action menu, click Scan for hardware changes.
8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3.
Uninstall all the usb controller from USB controller
and now restart the computer.
If this method does not resolve the issue, go to method 4 .
Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Hope this helps.
Jan 14, 2011 | Gateway 310 S PC Desktop
Dell Latitude D800-Win XP- My Dvd/rw wont write
Because you lost two devices, the DVD and the wireless mini card, I believe your problem is a drivers issue.
You should make sure you do not have any Malware that is removing these drivers.
If you have access to the Internet download and install Malwarebytes. It has a quick scan that will ID any infections.
Then get the newest drivers for those two devices from Dell's support site.
Before you install the drivers, remove those devices in Control Panel.
Mar 20, 2010 | Dell Latitude D800 Notebook
Usb ports no communication with compurter but supplies power. what is wrong ?
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Does the 'USB' branch of the tree show the USB ports?
Is there an 'Unknown Devices' branch of the tree?
Either way, the software "device-drivers" for the USB ports are not installed, or not installed correctly, and so you'll get the symptoms that you've observed -- power without device-recognition.
Access http://support.dell.com and click "Detect My Computer", and download and install the device-drivers for the USB ports.
Dec 30, 2009 | Dell Dimension 4600C PC Desktop
I need the usb controller driver for the dell dimension 2350 know where i can find it? thanks
The USB controller driver for Windows XP is a Native XP driver. If you have a problem with it, boot to the safe mode, go to device manager, remove the controller from list, make sure all USB devices are disconnected (Keyboard and Mouse excepted) reboot and let the controller re-detect.
If that doesn't work, then try a repair install of XP
Oct 21, 2009 | Dell Dimension 2350 PC Desktop
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
Dell dimension 5150 ethernet problem reloaded windows xp home from a windows xp entertainment os. apear fine but not receiving.
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Jul 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I Need Windows XP Drivers for Sony VAIO VGN-NS10L/S Laptop
Good day!!! I know the link for the VGN series for windows XP drivers you can download the drivers there ( http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/ ) hope this one can solve your problem.Cheers and God Bless.
Jun 23, 2009 | HP LaserJet P2015 Printer
No sound
Dell dimension 4400 drivers can be found here.
Apr 28, 2008 | E-Machines eMachines Desktop PC
WINDOWS XP
Windows xp can run on any PC that has a 233 mhz processor and 64mb of ram. Here is a list of hardware requirements for windows xp taken from microsofts website : These are the minimum requirements for basic functionality. Actual requirements vary, depending on the system configuration and the programs and features that you choose to install. If you are installing Windows XP over a network, you may need additional available hard-disk space. The minimum hardware requirements for Windows XP Home Edition are: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600)or higher resolution ? Sound card ? Speakers or headphones The minimum hardware requirements for Windows XP Professional include: ? Pentium 233-megahertz (MHz) processor or faster (300 MHz is recommended) ? At least 64 megabytes (MB) of RAM (128 MB is recommended) ? At least 1.5 gigabytes (GB) of available space on the hard disk ? CD-ROM or DVD-ROM drive ? Keyboard and a Microsoft Mouse or some other compatible pointing device ? Video adapter and monitor with Super VGA (800 x 600) or higher resolution ? Sound card ? Speakers or headphones
Aug 29, 2007 | Computers & Internet
Sabrent (USB-UF6) (USBUF6) Serial Adapter Logo
258 people viewed this question
Top Sabrent Computers & Internet Experts
Colin Stickland
Colin Stickland
Alun Cox
Larry Rider
Larry Rider
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
