Question about HP OfficeJet 6110 All-In-One InkJet Printer
Faxing with a digital phone line
I have trouble faxing over my digital phone line, I have CallVantage with AT&T. Seems the machine feeds all papers, but only "sends" the 1st sheet...ends up with an error report. Any advice?
Thank you. Elisia
    Problem Solver:
  • 11 Answers
You can't a fax machine on a digtal line unless it is a model specified for it.
Posted on Nov 05, 2008
    Novelist:
    Scholar:
  • 111 Answers
I looked up fax problems at HP.com and my guess, based on what I read, is that the 6110 is able to detect the broadband data connection at the higher line frequencies, even though all you hear on the line is a normal dial tone. If you haven't done so already, you'll need to install a line filter on one of your phone jacks (this should have come in the kit with the rest of the hardware you were sent to set up the DSL line). This isn't an issue with the 6110, but a natural "consequence" of using DSL.
Here's the web page I used as the basic for this opinion:
Phone "Off the Hook" Status
On that page scroll down to the "Checking the phone line" section and read the material there. See if that info helps. Good luck.
Posted on Nov 04, 2008
My Sharp UX-A255 won't let me fax anything. It starts up and then comes up with the message Line error or paper jam. There is nothing jammed.
Is it receiving faxes? Make sure you have the line in the right place in the back of the machine (line) and that you get dial tone (hit the monitor button if it has one). Try calling it on your cell to see if it picks up. You may have a poor phone line conditon, and you could try to slow the modem speed down or check the ECM (Error Correction Mode) if so. If it's a jamming problem, try to run a copy and see if it feeds ok. If not try cleaning the feed/pick up rollers with mild soap and water. Reseat the paper and try it again.
Oct 27, 2009 | Sharp UX A255 Plain Paper Thermal transfer...
Having trouble receiving faxes, takes several times of someone sending to me to receive.
First thing to check is the condition of the phone line, if the machine has a handset make a phone call from the handset, is the line clear? Is there any static or Echos on the line?
Is the machine on a shared line with computers or an answering machine?
Call the Fax machine from a phone, is the line clear? did the machine generate its handshake burst? Did anything else try to answer the line?
Check the phone cable input, it should be going onto the LINE jack on the back of the machine.
Apr 15, 2009 | Brother IntelliFax-1860C Plain Paper...
I'm having trouble faxing.
Check the phone line with a regular phone.
Jan 28, 2009 | Brother IntelliFAX 560 Plain Paper Fax
MFS8220
Do you have a DSL or any other type of digital phone line?
Oct 10, 2008 | Brother MFC-8220 Fax
Sending a fax
Its the phone line causing the problem. Check the line via the handset, if you hear static sounds you have a bad line. Contact your phone provider and have it checked/fixed.
Also check the feeding of your original by using the copy function. It is possible that you have a feeding issue but I would bet on it being the line.
Feb 20, 2008 | Brother FAX-575 Plain Paper Thermal
Line error when trying to send a document
Check the line for a dial tone on the machine. Either the handset, onhook or speaker phone button. This will test if any comunictions boards have failed in the machine. If you have a dial tone the fax is ok
Next try a manual transmission. Basically make a normal phone call with for example using the handset but have your original in the fax ready to go, ring the fax number when you hear the other fax pick up you press the start button.
Don't forget the other fax may have a problem.
Jan 31, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Sharp UX110 Fax Machine (about 10 years old!)
Its the adf unit not sensing the original.Most systems use either a photointerrupter or a switch. Which when they go out it not feed.      But you may also have a bad original feed motor.You can always test the line by hitting the hook/monitor button,or plug a phone in the wall and listen for the tone.
Oct 17, 2007 | Office Equipment & Supplies
Can't send faxes - Panasonic KX-FPG372 Fax machine
THE PHONE SEEMS TO BE GETING DISTORTED ,IT MAY BE IN THE PATH OF THES DIGITAL BOXES. PLS CHANGE THE LINE OR LOACTION HAPPY FAXING OMNIPRESENT
Sep 07, 2007 | Panasonic KX-FPG372 Plain Paper Thermal...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
147 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
