Question about Garmin GPS
I need to know how to connect my nuvi200w to my pc What lead do i need and what port do i connect it to to down load updates?
I whent back to the start of the process and whent through it again and discovered by chance that
the down load had been completed successfully.
Posted on Nov 05, 2008
I have a lexmark2500 printer and im trying to connect to my toshiba lab
Plug in usb and power leads to make connection with laptop.
Click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click to update driver. Hope this helps.
Jan 16, 2013 | Toshiba Satellite Computers & Internet
Usb ports not working?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
Apr 17, 2012 | Dell Inspiron 5100 Laptop
I have a acer M5100. Just added new card and now the HDMI port no longer functions. How do I enable it again or do I need to down load teh driver again and where can I get that?
This is almost certainly a driver issue. I know that a lot of ATI cards when installed have problems with HDMI ports. Updating your drivers and installing the Realtek High Definition Codecs (found here) will generally fix the issue.
If that doesn't work, let me know and I will get back to you. If you need more help, be sure to tell me what graphics card you are using and if the HDMI port in question is on that card.
Mar 29, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
I HAVE FORMATTED MY PC AND RELOADED THE WINDOWS XP, AFTER LOADING THE HARDWARE DRIVER, SOMETHING WENT UNUSUAL AND SYSTEM SHUTSDOWN EACHDOWN WHEN AFTER BOOTING WINDOWS XP. THEN I RELOADED WINDOWS XP AGAIN....
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 24, 2011 | EliteGroup ECS P4M800-M Socket...
Can i down load the webupdater for free? my garmin needs to ''get a new brain'' but i havnt got any of the connection leeds or the cd with the wed updater. what are my options?
Basically, you have no options unless you purchase or borrow accessories.
You're going to need the connection leads to make any software or firmware updates as there's no other way to get them from a host pc to your satnav.
I suggest that you visit the Garmin website to see what leads you need (and to download any software) and then check out the likes of eBay or Amazon as the leads are often cheaper elsewhere.
Please take a moment to rate my reply.
Jul 22, 2010 | Garmin nuvi 205W GPS Receiver
Computer won't detect my nuvi 255T when I plug it in to USB port to register it on the Garmin website
go to garmin and down load the web updater in downloads first .........then connect and go to programmes in pc and select garmin then run web updater , if no good try a different usb lead
Jan 02, 2010 | Garmin nuvi 255W GPS Receiver
Photo viewer device not found
I got a key ring for Christmas too ...when the keyring is on 'charge' mode it doesnt show on computer ...you have to remove the lead from key ring, switch off key ring then replace lead and switch to 'update' mode. Now if you double click on icon it should work!!!
Nov 22, 2009 | Fuji Electronics - Others
How do you update the firmware of Fuji S7000?
What you do is have an ac mains adapter or a fully charged battery, a formatted card in your camera ( there should be a setting in your cameras menu for formatting) and the usb lead connected to your camera and pc. This should all be in your owners manual if you have one ( if not you can download one from a fuji website).
Check for a firmware update on a fuji website ( I had a look on a few and didn't find one) and down load it to your computer.
To check your current version hold the display back button down and turn the camera on. It should display the current version and ask if you want to up grade. If you don't ,or can't, turn off your camera.
Basically you down load the up date, then up load to your camera using the usb lead following any instructions along the way (get the manual for instructions. It will be easier). Mains lead is preferable as a battery could die halfway through and then you will be in trouble.
Hope this helps
Oct 06, 2009 | Fuji FinePix S700 Digital Camera
I want to update my Nuvi200w,I have the data cable but I need to know what to do next. Please help.
First of all find current firmware.
To view the current firmware version, complete the following steps:
  1. Turn on the GPS.
  2. Switch to the tool kit page by touching the tool symbol on the buttom row.
  3. Touch "Settings".
  4. Touch "System".
  5. Touch "About"
  6. The system will display the firmware version at the top("SoftwareVersion"), the unit ID on the second line, followed byvarious copyright information.
  7. Touch "Back" to return to the previous page.
For online updating you must have Webupdater
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Afterinstalling WebUpdater once from the Garmin website, perform all futuresoftware updates from your computer. Simply connect your compatibleGarmin device to your computer, then run WebUpdater from your computer's"Start Menu" by selecting "Start", "Programs","Garmin", and finally"WebUpdater".
Attention! It were cases that unit software was newerthan on Garmin site and it were losings of local language support afteronline updates. You must deside before do you need these changes offirmware or it's not so important.
Sep 11, 2009 | Garmin nuvi 200W GPS Receiver
Map update for Nuvi200W
First of all, you have to register your unit to Garmin, then you will receive a link including updating map information.
Unfortunately, it's not free.
Jun 18, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
66 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
