Question about HP iPAQ HX2490 Pocket PC
HP 2490B SD CARD
HP 2490B WILL NOT READ SD CARD BUT MY DELL X51V WILL MY HP LAPTOP WILL NOT READ IT EITHER , IS THERE A DIFF ONE I SHOULD TRY OR USE A COMPACT FASH CARD
  • 80 Answers
Check if your SD is SD HC because it cant read HC
Posted on Nov 15, 2008
Is thare a sim slot in dell axim 51v
Musaji Ahmed Hariff,
Your device has two slots located on the top of the unit. The larger slot supports CompactFlash Type II cards. The smaller slot supports Secure Digital (SD) memory cards, Secure Digital I/O (SDIO) cards, and the MultiMediaCard (MMC). All three memory card types are available in sizes from 64 MB to 1 GB or 2 GB. CompactFlash Cards Your device supports CompactFlash Type II cards. Some common types of cards include: • Modem - Connect a telephone line for modem data communication. • Wireless communication - Data communication without the use of cable connections. You can use cards, such as internal cards with Bluetooth wireless technology and 802.11b wireless LAN. • Storage - Save data or install programs on a storage card
You can click the link below to download the online manual for the Axim51v
http://dell.to/1WKDE1W
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Oct 05, 2015 | Dell Axim X51v Pocket PC
Dell Axim X51v Pocket PC, i can connect to a wireless network, but i cant open any pages, such as google?? any help would be greatly apreciated!
Go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab', and make sure that 'My network card connects to' is set to 'The Internet'.
Hope it works for you!
Just my 2 cents... Carlos
Apr 14, 2010 | Dell Axim X51v Pocket PC
I have a dell axim x51v stuck on dell logo
First check to see if any of the buttons are stuck. If that doesn't help, try a few simple things with the digitizer, the thing you write on. It could be stuck.If there are any gouges, dents, deep scratches or cracks, that could do it, it's toast - but self repairable if you dare. -However- 2 things to try first just for giggles though if there are no cracks: #1. Use your joystick & enter button to navigate through the Start Menu to Settings>>System>>Screen>> Align Screen and align the screen. Worth a try. #2. There might be some crud stuck between the edge of the digitizer and the edge of the case. That can give you phantom key presses. Take a piece of stiff paper or thin plastic and run it *gently* around under the edge where the case covers the screen to scoop out any stuff that may have settled there. Those blister packs that cut you up when you try to open them works well, credit card is too thick for my taste. #3. If it's been around water, there's a very slight chance that putting it on top of the clothes dryer for a few loads will dry it out.Beyond that, needs technical help.
Mar 16, 2010 | Dell Axim X51v Pocket PC
How to install windows mobile 6.5 on a dell axim
the only way to install windows mobile on your axim x51v is to get ahold of a ROM specifically for that model. the operating system is still only in beta testing so even if you do find the ROM there will be no support and it could be buggy. If you can find a ROM you just have to put it on a 1 or 2 gig SD card. it cannot be an SDHC card. then you press the power button, reset button on the back and the wireless button on the side all at the same time. this should start the ROM loader. just select the ROM on the card. it will then proceed to install it. you want to have the PDA plugged into AC power for this.
note that this process can be risky and if something does go wrong your PDA may be ruined and your on your own.
Sep 07, 2009 | Dell Axim X51v Pocket PC
I have a dell axim x51v, I does not stay operational
seems to be some problem with the battery itself. Try charging it fully and then check. Does the battery dip when the phone turns off?
Jul 08, 2009 | Dell Axim X51v Pocket PC
Dell Axim x51v that will not power on.
Assuming the battery is not dead, try taking the battery out for a few seconds to be sure the PDA is turned all the way off. Put the battery back in and close the back. Use the stylus to hold the reset button in (on the back) while you press and hold the power button. If the battery is dead do this while it is connected to the charger. It should diplay a message telling you to press the mail button (to the left of the cursor control button) to the reset to factory defaults. Caution this will erase everything in the built in memory including any programs you installed after you recieved it.
Hope this helps
Dec 15, 2008 | Dell Axim X51v Pocket PC
Broken SD slot
Its possible to take it apart and perhaps fix it, however, the real challenge will be not causing more damage than already exists. So the question is do you need the SD slot working bad enough to risk the entire unit? I wouldn?t recommend disassembling a handheld PC unless you have the tools and the experience working with delicate electronics in tight spaces. If you want to pursue the disassembly process let us know.
Feb 10, 2007 | HP iPAQ H2210 Pocket PC
Can Not read SD Card
Have you tried the SD card in a digital camera? also is the card working correctly?
About the internet it will have to be correctly set up which means some fiddling around with the connections settings
Aug 05, 2006 | Dell Axim X30 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
444 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
