My age 77 need help setting up raido - Audio Players & Recorders
VOLKA
Posted on Nov 05, 2008
Have 77 ford f150 that doesn't run smoothly, have put in refurb carburetor, what else could be problem?
Get a compression tester and check all the cylinders. Find out what the pressure should be allowing for age and all pots should be within 10lbs of each other. If you study the plug tips when you remove them the colour may give you a clue. Light brown centre is right, dirty or discoloured is not. To check compressions leave plugs out and hold foot on the gas during cranking. Full pressure should be there in 4-5 secs. Be aware of plug leads during test.
May 30, 2014 | 1977-1979 Ford F150 Truck Complete...
YOUTUBE SAYS I'M TOO YOUNG TO VIEW THE MOVIES ,,I'M 77 YEARS OLD ,,HOW MUCH OLDER DO I HAVE TO F -N BE??
no good complaining to fixya site
nothing we can do
however there is something you can do
get a young child to show you how to reset your age to ficx the problem
Nov 15, 2017 | Cell Phones
Have a CD stuck in the CD player, what is the best method for removal?
Hi
You can disconect the battery let it sit for 15 minn and then reconect the battery this will power down the raido ,, if the cd is not damaged or warped it will now eject, ,,,, If the cd is damaged you will need to remove the raido and have the cd removed by a raido tech the raido will need to be takiin apart.
Jul 13, 2010 | 2003 Dodge Neon
I had to get a new battery and now my radio wont
YOUR RAIDO HAS A CODE # TO PREVENT THEFT, YOUR DEALER CAN GIVE YOU THE CODE. WHEN YOU REMOVED BATTERY RAIDO THEFT CODE WAS SET OFF IN RAIDO.
Feb 01, 2010 | 1999 Buick Regal
Setting Clock on Delco Raido
Push the set button and then use the seek and scan buttons to increment hour and minutes.Scan is hours and seek is minutes.Sometimes the radio has to be off and sometimes it can be on.Hope this helps.Good luck.
Dec 23, 2009 | 1992 Buick LeSabre
Can not get temp below 77
Is the thermostat set up for automatic change over from heat to cool? If so, the heat is probably set for 75, you will need to lower the heat setting in order to Lower the cooling. the stat won't let these settings with in 2 degrees of each other so the heating and cooling don't fight each other.
Aug 25, 2009 | Heating & Cooling
Cobra 29 LTD classic when turned on it shuts off
Well I hope you didn't clip D12. D11 makes sense to me. If you clip that you are disabling the AMC, automatic modulation circuit. This will allow the radio to modulate at full modulation all the time, which isn't always good. You can over driver your final and possibly blow it.
Most of the time you can just turn up VR4. thats the AMC adjustment. It will raise your modulation to the max but will not over modulate it.
You probably blew the final and or more components as well. Your going to have to take it to a radio tech. This is no simple fix.
Jan 26, 2009 | Cobra 29 LTD CB Radio
20 people viewed this question
 Grubhead
Grubhead
