Question about iLO (2 GB) MP3 Player
Mp3 promble i dont know where what usb port to plug it in
    Problem Solver:
  • 8 Answers
PLUG THE WHITE ONE IT CAME WITH
Posted on Nov 06, 2008
Hi, I have this problem with my Sony walkman NWZ-B152F that when ever have I connected with my PC, it does not open or gets charged. the minimum PC configuration are all met yet the promble persist and in...
I own this same MP3 player. Had this happen to me and I have a great laptop too. Just out of the blue it would not work in any of my USB ports. When your MP3 is plugged into your USB port you should be able to click on "devices" and go to your MP3 player and there should be a option to fix the driver. It will update the driver for the MP3 player. What's happening is your driver is not recognizing the MP3 player. No biggie, you just have to make it recognize it again.
Regards, Tony
Apr 15, 2011 | Sony Walkman NWZ-B135 MP3 Player
Dont recognize to my pc
Try plugging it into a different usb port on the computer. If it does not work, try using a usb adapter to plug in to the usb port. It may also help if you restart the computer and connect it again. If this does not solve the problem, then the usb of the walkman mp3 player got fried which is due to improper disconnecting procedure of the mp3 from the computer; so make sure when removing any mp3 device, do a "safely remove" procedure.
Mar 01, 2011 | Sony Walkman NWZ-B135 MP3 Player
How dont know how to charge my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Philips GoGear Flash MP3 Player
Trio clip USB port
As long as you still have the battery information, that should tell you the compatability of the MP3.( If you don't have any info, then look for a USB cable that has a similar sized USB jack. You could also google the model number, which should be on the device itself.)
May 29, 2009 | Mach Speed Trio Clip MP3 Player
I dont know hopw to charge it
thats because it doesn't charge plugging it in lets you sync files from your comp it runs on batteries open the usb cover then slide the bottom off to replace the battery.
Feb 27, 2009 | Nextar MA933A MP3 Player
Mp3 problem
One you plug in an MP3 player on a USB port it is normally recognized if you are using Windows XP. What you need to do is Open up My Computer then you will see your MP3 there under removable storage.
If you need further assistance please dont hesitate to contact me.
Sep 24, 2008 | RCA TH1101 MP3 Player
Still messed up.
hi yes it should be in recovery mode when doing this
does the firmware tell you when to connect the mp3 player to computer once in recovery mode open firmware file then when it asks to connect then plug into your comp if it dont work this way then plug into comp before opening firmware file give this way a try also.
But the mp3 player needs to be in recovery mode whilst doing this
if this still dont work then try a different usb port failing this then their is a problem with either the cable or usb port or conection on mp3 check cable and connections at both ends make sure no dirt or paper is stuck in mp3 end ok
Let me know what happens ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
I dont know what's wrong !!!!
I had to roll back to Windows Media Player 10 and then plug into different usb ports until my iriver was recognized.
Sep 22, 2007 | iRiver iFP-880 MP3 Player
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
USB Device Not Recognized
ok i dont know if you have had a solution yet but if you have the operating system Windows XP you dont need the software, just plug your USB plug up to your computer and MP3 and it should install the drivers
Mar 29, 2007 | Memorex MMP3642 MP3 Player
iLO (2 GB) MP3 Player Logo
15 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
