Question about Sony KP-61HS10 61" Rear Projection Television
Hi Im Very Interested In Your Outcome........with the KP-61HS10 Problem
I have the Same 5 blinks with sound but without picture. I was hoping one of the other posters with the same problem could tell me about their experience,,,,, What finally happened ? What was wrong? How much was the fix? How long did it take to get your set back? I hope all is well and that you check back for a follow up reply. Thanks so much.
  • Themr Dev Dec 20, 2007
    very much appreciated !
    First Sony tech tried and failed ...he was out 3 times.
    I saw him try a power converter...but that wasn't it.
    maybe this information will help the next not so savvy technician.
    Very much appreciated!
    I've had a SONY tech out 3 times and he still didn't fix it...
    but still charged me ..go figure.
    Nearly 300. for nothing. Well I did see him try a power something or other may a converter or conditioner.
    Maybe this info will help the next not so savvy technitian.
    President:
  • 4,402 Answers
· 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
AKB is a color balance circuit. It stands for Automatic Kathode Balance and is used in the video circuitry to keep the white balance in the proper level when dosed with color signals that tend to saturate the video level.
It is part of the "jungle IC" in Sony sets and is very important to the overall function of the color processing system.
The repair probably requires some surgery on the jungle chip if not its replacement. Cost of repair could be anywhere from a few dollars to $200 for the new chip.
It will require a service tech with good experience to know about this function, which is quite esoteric in tv engineering principles.
The only suggestion I have before you call in a tech is to do the hard reset (unplug for at least 4 hours) and the vibration check for loose connections or cold solder joints (by whacking the set with your hand or fist with enough force to vibrate the connections inside for bringing them back to life).
Posted on Dec 20, 2007
What's your problem?Hi, I have a Sony projection TV KP-46WT510 theres no picture or sound, but it still turns on and I can see the the on screen menu. When I turn it on the led blinks four times
You can Google and find the service manual which will explain what the 4 blinks means.
If you have the Sony remote with the set off:
Display, 5, Volume down, Power
If the set has it you will see a box appear on screen with a list of items--all should have a zero to the right of each---one with a number indicates the number of times that error has been detected.
Let me know if you have questions or cannot find what the four means and I will research it.
Mar 28, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp53s65
A rather older set:
picture blinks may be screen controls now set too low
picture dark same or lens need cleaning
color off either adjustments or a Convergence issue
Mar 16, 2012 | Sony KP-53S65 53" Rear Projection...
Toshiba model 42 Hp 95 has no picture, no sound and red-light blinks on front power switch has no effect
Depending on how many blinks you got here will determine the outcome of a solution here at Fixya or anywhere else, I am kinda wondering what the expert in chat is saying. But if you can update me with the SOS blinks on the front of your set, This will tell me how I can approach this situation.
thanks For your interested in Fixya.com I will be awaiting your reply.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 28, 2010 | Televison & Video
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
KP-41T15
On the pcb labeled (G) board look for location RY602
the replacment sony part number is # 1-755-018-11
this is the repair for stand by light blinking.
Thi is the repair for Power light blinging.
Q601, Q602 parts number(2sc4843)
r606 0.1ohm 1/2w also replace c604 and c605.
hope this helps,
regards,
daniel.
Jan 03, 2009 | Sony KP-41T25 41" TV
Sony 57"kp-20fm12 hi scan 1080i rear prjection
That blinks and flashing have a diagnostic code. I have a list of the problems that might have occurred indicated by the number of blinks or flash. Tim just post the number of flash or blink,so i give you diagnostic code meaning...
Hope it may help you;
Regards,
VOTIT
Oct 02, 2008 | Sony KP-57WV600 57" Rear Projection...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Exact same problem with my kp-51ws500!
i think the colorwheel may be bad if you have no picture but sound,
Jun 23, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
